I got rid of the wagon
now I picked up an AWD sedan (94)
now all i have to figure out is:
Stiff Shifter (automatic)
shaky speedo
no turn signals (hazards work)
and a ticking sound from under hood
at least it only has 135k on it, fairly rust free, sunroof, ABS, and AWD
I'm back!
internetautomart
I'm back!
94 BC w/ AWD Sold 6/25/08
92 BJ Rust bucket gone
90 BC (I think) Stripper, gone since 2k
86 GL10 Turbo 4wd, Gone since 99
internetautomart
internetautomart
mine I hear at idle, not sure above that right now.Trace wrote:Could you elaborate more on the ticking sound from the hood? it starts to click around 2900 rpm is yours like that as well?
tris91ricer
- Title Whore
If you hear the 'clicking' at idle I'd say its in need of an oil change. If the sound gets worse as the rpms get higher, you've got a bigger problem. Other than that, subies have a noisier valvetrain than most other cars.
If your turn signals don't work, but you have hazards, you might need to check your blinker relay and connections.
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
EJ20g 4.11 5sp LSD
[/quote]
internetautomart
yeah, I'm assuming it's just old oil. car has been sitting for about a year.tris91ricer wrote:If you hear the 'clicking' at idle I'd say its in need of an oil change. If the sound gets worse as the rpms get higher, you've got a bigger problem. Other than that, subies have a noisier valvetrain than most other cars.
it's at the shop now, hopefully everything checks out alright and then I'll start getting the car in shape
