Hey there....well its starting to get really cold here in CT and on top of my heat blower motor not working (I read a lot of posts and have heaps of things to try) my rear defroster isn't working at all either.
Has anyone had this problem? Any hints?
Thanks - Justin
Rear Electrical Defroster
Well for the rear, check the fuse first. then turn it on and check for voltage at each side of the window where the wire bonds with the window. If you have voltage there, then check each grill that doesn't have any voltage. Get rear window repair paint.
'11 WRX Limited
'94 TW | R.I.P.
