I just recieved an Autometer air/fuel ratio gauge and need to identify the
wires on the 02 sensor to install it. I have a 3-wire 02 with black, red
and white wires. anyone know which one I need to connect the gauge to? Does
anyone having a wiring digram for a '92 Turbo Legacy?
THanks,
PeteH
BTW, sorry to hear about your goodies getting ripped off Bill, I hope you
make out OK with your insurance........
02 sensor info
02 sensor info
black should be ground, red should be 12volt, white should be the
wire you want..check with a volt meter..
02 sensor info
That is what I figured but didn't want to hook it up wrong because
the Autometer manual states :(Do not connect ohm meter to oxygen
sensor, or touch wire to ground or power. Damage to oxygen sensor
will result. If a volt meter is to be used, only use a high impedence
(10 mega ohm or higher) digital multimeter. Note: do not disconnect
wire to the computer.)
Has anyone installed this unit in a Sube?
TIA
Peteh
TIA
Peteh
