Hey guys, I am looking at getting a set of 06 sti wheels. I believe the lug pattern is 5x114 is that true? Is there any way to swap hubs to make them work? How about SVX parts?
I am looking at getting them for $100 here in Idaho.
Thanks,
-Devan
06' STi Wheels
livestrong14
06' STi Wheels
91 SS -Carbon Bronze Pearl
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
91 Rio Red SS- RallyX Project
93 AWD Sedan- FOR SALE!
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
I have heard about hub adapters, but haven't looked into them.
You'd also be running an 8" wide wheel on a BC. Gooooood luck with that.
Legacy Central
hub adapters are garbage and a VERY bad idea.
#1- gives an extra 15-20mm positive offset
#2- have to cut the existing studs to get them to fit
That should really be enough to convince you.
8" +53et wheels with 225s should clear ground control sleeves and rolled fenders. It puts the tire in the same place as my 7" wide wheels and I'm running 225s.
dscoobydoo
8" wheels are a pain in the ass to fit, trust me; I spent about six hours over the course of two nights getting mine to BARELY clear the spring perches.
we're talking such small clearance that for the first 200 miles anything over 90mph made a high pitched rubbing noise as the tires expanded. now that the tread has a little new worn off of it they do better (no more rubbing) but it's not worth it unless you have coilovers.
and expect to roll your fenders a good deal to get them to clear, or you'll chew them up.
get 7.5" wheels, much less hassle.
#82 M4 TRSCCA Rallycross
I know someone who used STi rear knuckles with svx rotors and backing plates to use normal rear brakes on his Impreza coupe. You can make hybrid axles, but things add up very quickly.
Step one: Buy wheels for $100
Step two: Post on NASIOC
Step three: ????????
Step four: Profit
Step four: Profit
