ticking sound under part throttle
Hey people...
I am having this problem of a slight ticking sound under part
throttle... and that is very light part throttle, normal city
cruising at approx 60-70km/h at 4th gear..... any more throttle, that
ticking sound dissapears, and if i let it off a bit, it also
dissapears, anyone have any idea what it is? it happens under both
warm and cold engine temps, changed to NGK plug wires today, sound
stayed the same....
i changed my spark plugs 4000km ago, 15W40 oil 4000kms, using K&N
filter, and took out resonator.
stayed the same....
Have you replaced your boost solenoid yet?
My AVC-R's actuator valve, which controls boost, makes a lot of
noise. I didn't notice my stock one clicking, but that could very
well be it.
--- In BC-BFLegacyWorks@y..., "Ricky" <prostho@n...> wrote:
> Hey people...
that
> stayed the same....
well be it.
> Hey people...
that
> stayed the same....
Ricky
sound like a tikkey wifter, or a sticky lifter, perhaps some sludge remover. the thin stuff you put in a cold engine, start, idle till warm (10 min) then new oil and filter. That helped my tick.
isn't your oil a little heavy. 15w40 is what i use in my VW diesel, Subies like 5w30 better, or if it's hot where you are perhaps 5w40.
seeya
Gord
-----Original Message-----
Sent: 17-Apr-01 3:30 AM
Subject: [BC-BFLegacyWorks] ticking sound under part throttle
Hey people...
stayed the same....
<http://rd.yahoo.com/M=190462.1393721.29 ... icated.com> www.debticated.com
<http://us.adserver.yahoo.com/l?M=190462 ... =643171682>
seeya
Gord
Hey people...
stayed the same....
Gord,
My subaru dealer recommends and uses 15W40 Diesel oil for my Liberty RS Turbo - makes less ticking noise ( I think)
Cheers
Ross
----- Original Message -----
Sent: Wednesday, 18 April 2001 4:17 AM
Subject: RE: [BC-BFLegacyWorks] ticking sound under part throttle
Ricky
seeya
Gord
Hey people...
stayed the same....
<http://rd.yahoo.com/M=190481.1393724.29 ... direct.com> www.newaydirect.com
<http://us.adserver.yahoo.com/l?M=190481 ... =244750366>
Cheers
Ross
Ricky
seeya
Gord
Hey people...
stayed the same....
Actually, this is exactly what i am using.. Agip Superguard oil,
15W40 for diesel engines.. my mechanic say it might work good for
turbo application, so i used it....
--- In BC-BFLegacyWorks@y..., "Ross" <vecc@t...> wrote:
> Gord,
> Cheers
> Ross
> Gord,
> Cheers
> Ross
Just to add more confusion, a couple of months ago I put Motul 300V
15W50 in my Legacy RS Turbo, and it started ticking like it had never
done before. We still have a temperature around 5C degrees here in
Finland, I guess it would be better to use this grade of oil when
it's warmer...
* Miki *
> > Gord,
> > Cheers
> > Ross
it's warmer...
* Miki *
> > Gord,
> > Cheers
> > Ross
Hmm.... maybe i should change to 5W30 next oil change to and see what
happens then...
O yeah, after really listening to the sound closely, it actually only
ticks when i apply throttle lightly to accelerate... if i just keep
my foot at same throttle position, and it accelerates to around 70
til it just cruises around there, the tick stops.. this means that it
only ticks when the engine is under load....
never
> it's warmer...
> * Miki *
happens then...
never
> it's warmer...
> * Miki *
I still think it's the solenoid...but i'm probably wrong.
what
> happens then...
only
it
300V
> never
in
> > it's warmer...
> > * Miki *
oil,
for
what
> happens then...
only
it
300V
> never
in
> > it's warmer...
> > * Miki *
oil,
for
I'll see if it is later when i can actually get my lazy butt off the
chair and replace it. haha.. and i also need $$!
the reason i believe its not the solenoind is becoz my boost guage is
reading negative pressure around -15 to -21 hgm or something like
that when its lightly accelerating, which is normal i believe? i
don't think my wastegate would be doing any work under negative
pressure would it?
> what
> > happens then...
> only
keep
70
that
> it
> 300V
> > never
> in
when
> > > it's warmer...
> > > * Miki *
> oil,
> for
pressure would it?
> what
> > happens then...
> only
keep
70
that
> it
> 300V
> > never
> in
when
> > > it's warmer...
> > > * Miki *
> oil,
> for
Yes, my guauge also reads negative untill you develope boost.
Mark
www.rrunracing.com
>From: "Ricky" <prostho@netscape.net>
>Reply-To: BC-BFLegacyWorks@yahoogroups.com
>Subject: [BC-BFLegacyWorks] Re: ticking sound under part throttle
>Date: Fri, 20 Apr 2001 04:29:24 -0000
>pressure would it?
> > what
> > > happens then...
> > only
>keep
>70
>that
> > it
> > 300V
> > > never
> > in
>when
> > > > it's warmer...
> > > > * Miki *
> > oil,
> > for
_________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
Mark
www.rrunracing.com
>pressure would it?
> > what
> > > happens then...
> > only
>keep
>70
>that
> > it
> > 300V
> > > never
> > in
>when
> > > > it's warmer...
> > > > * Miki *
> > oil,
> > for
Ricky-might be a stupid suggestion, but have you checked for exhaust leaks?? just a thought-ROD_AZ.
Sent: Thursday, April 19, 2001 9:29 PM
pressure would it?
> what
> > happens then...
> only
keep
70
that
> it
> 300V
> > never
> in
when
> > > it's warmer...
> > > * Miki *
> oil,
> for
<http://rd.yahoo.com/M=135184.947800.265 ... promo.html> Click Here!
<http://us.adserver.yahoo.com/l?M=135184 ... =634941384>
pressure would it?
> what
> > happens then...
> only
keep
70
that
> it
> 300V
> > never
> in
when
> > > it's warmer...
> > > * Miki *
> oil,
> for
Hmm.. haven't checked for exhaust leak... will check.. but unlikely
because if its exhaust leak it should tick all the time, under full
throttle or no throttle...
mine used to tick on another car I thought it was just a worn engine untill I tightened up the exhaust engine manifold and bingo no ticking
¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø¤º°`°º¤ø,¸¸,¤º°`°º¤ø,¸¸
Info: John Carlsson UK 92 Legacy 4 cam Turbo Estate
E-mail : penty@nettaxi.com < mailto:penty@nettaxi.com>
Sent: 21 April 2001 08:59
<http://us.adserver.yahoo.com/l?M=190462 ... =394872909>
My Subaru has done the same after using ELF Synthetic 15w50 Oil, it
is the hydraulic tappets, with the Subaru hydraulic tappets it pays
to flush the oil at each oil change, to reduce this noise. The
viscosity of this oil is different than recommended, which is why the
tappets react like this. You should never use diesel oils in petrol
cars!!
Daniel
the
is
> pressure would it?
see
> > what
> > > happens then...
actually
> > only
> keep
> 70
> that
> > it
Motul
> > 300V
had
> > > never
here
> > in
> when
> > > > it's warmer...
> > > > * Miki *
> > oil,
good
> > for
cars!!
Daniel
the
is
> pressure would it?
see
> > what
> > > happens then...
actually
> > only
> keep
> 70
> that
> > it
Motul
> > 300V
had
> > > never
here
> > in
> when
> > > > it's warmer...
> > > > * Miki *
> > oil,
good
> > for
