Why oh why did they change shifters??
New92
Post by New92 »
I had learned the hard way (by purchasing a MikeY. custom shifter) that the '92 and '93 do not share the same shifter assembly. NOW Im really mad.......
http://www.horsepowerfreaks.com/price/S ... ort_Manual
Ah well, I would drive with my boot off just so I could look at it while I drive :-D
1992 SS 5MT
What year is that supposedly meant for?
If it's just the shifter lever, you can replace the linkage. I highly doubt the b&m unit you'd get for the legacy looks like what is in the picture.
Bottom line is you can use any newer style shifter if you're willing to replace the linkage & joint with a newer unit.
New92
Post by New92 »
Info says its for MY'93 and up, so should work on anyone who has the MikeY lever installed. Im sure its not the same unit. I know I can do a full swap from the boss to the lever, just not in my plans at the moment. I just thought it was cool. What I wish I could get is a ball bearing shift kit. I tried one on a buddies Mach1 and it was perfect. Would work great with a crash or dog box tranny.
1992 SS 5MT
206er
Post by 206er »
ok ball bearing shift kit? that is retarded overkill. none of those pivots move more than 20* or so.
a subaru trans is never going to feel super smooth.
(i have all delrin shift bushings and it feels ok)
New92
Post by New92 »
New92 wrote: Would work great with a crash or dog box tranny.
^^^^^^^^^^^^^^^^^^^^ :wink: I was thinking that the more precise shift points would make managing one of those transmission types a bit easier.
1992 SS 5MT
New92
Post by New92 »
Was not thinking of using it with a stocker. I agree, it would be overkill in that situation.
1992 SS 5MT
Where does one aquire delrin busings?
Threshld1
Post by Threshld1 »
http://www.allwheelengineering.com/bask ... ass=KB-003
The 97-05 5MT bushings will fit and all the rear bushings are the same. Keep in mind these are the stay bar bushings. They will help a lot with slop but if your linkage bushings are shot it will still be floppy. Linkage bushings can be gotten at subaru.
93 SS 5MT - TD05H-16G, 06 TMIC, Walbro, Zeitronix WB-02 - Scrapped too much rust
91 SS AT
97 Outback - Prodrive quick rack, DMS 40
n2x4
Post by n2x4 »
I have a WRX linkage with Kartboy front and rear bushings and Kartboy short throw lever. It's so crisp.
SUBARUEHS Racing
206er
Post by 206er »
beatersubi wrote:Where does one aquire delrin busings?
you makes them :P
you makes them :P
Out of what? :D
Rephrase: where would one aquire delrin for making bushings?
Any industrial or plastics supplier. It's basically nylon that tolerates exposure to water better. It's pretty easy to machine, reasonably hard with good wear characteristics, and low friction. You may even be able to find a cutting board to make bushings out of since it might be FDA approved for food use, though I know HDPE is and they use that for cutting boards and processing plants. Unfortunately, you wouldn't want HDPE for bushings.
If you come across colored (red, green, dark blue, etc.) HDPE no thicker than 1/4" (though preferably 1/8 ), let me know - I need some to build a coffee maker I designed, but all I can find is damned white and sometimes black.
ciper
Post by ciper »
If a part says "MY93 and up" that means IMPREZA not Legacy.
206er
Post by 206er »
beatersubi wrote:
you makes them :P
Out of what? :D
there should be several plastics shops in the tacoma area, for some reason I remember the name TAP plastics?? should be in the phone book.
206er wrote:
beatersubi wrote:
206er wrote:you makes them :P
Out of what? :D
Wow, thanks. Never thought I'd recieve local help from a CO resident.
