Hi Alex
Congrats on your install
Yes, I would be very interested to see your diagram, but I am thinking there
is too little space between our turbo outlet pointed upward in the wrong
direction, and the cooler inlet to get a freeflowing transition, without some
kind of big spiral loop all the way over the top of the cooler and back
around under the bottom to the inlet. I think Bill Robinson cut off part of
his cooler inlet and welded up some elbows to get a fit.
I kind of don't want to introduce any sharp bends into the system, and really
think I'm going to end up spending more $$ to go for the EJ20 turbo with the
correct clocking, but hey, let's see those pics!
More than one source has said the wires on top of the cooler are from a
sensor that energizes a light on the dash when the water level is low
And now the questions
1. Have you (or anybody) noticed whether your turbo is bolted in such a way
that the outlet cannot be clocked horizontally to make a straight shot at the
intercooler inlet?
2. What are you using for a pump?
3. What are you using for a radiator?
Larry back to the drawing board Witherspoon
<http://rd.yahoo.com/M=190462.1393721.29 ... icated.com> www.debticated.com
<http://us.adserver.yahoo.com/l?M=190462 ... =694439204>
intercooler install
intercooler install
Hi Larry I e-mailed the pictures to you I am afraid that you won't be
able to see very much. I did have some answers for you. Are there any
of the 2.0L turbos available? What the elbows do is simulate the old
ducting and are pretty close.
--- In BC-BFLegacyWorks@y..., ssspoon@a... wrote:
> Hi Alex
thinking there
wrong
without some
back
part of
and really
with the
from a
low
such a way
shot at the
> intercooler inlet?
> Hi Alex
thinking there
wrong
without some
back
part of
and really
with the
from a
low
such a way
shot at the
> intercooler inlet?
intercooler install
HI guys check this out http://www.netcomuk.co.uk/~gavinp/airwater.htm
----- Original Message -----
To: <BC-BFLegacyWorks@yahoogroups.com>
Sent: Saturday, May 12, 2001 4:16 AM
Subject: [BC-BFLegacyWorks] Re: intercooler install
> > Hi Alex
> thinking there
> wrong
> without some
> back
> part of
> and really
> with the
> from a
> low
> such a way
> shot at the
> > intercooler inlet?
> > Hi Alex
> thinking there
> wrong
> without some
> back
> part of
> and really
> with the
> from a
> low
> such a way
> shot at the
> > intercooler inlet?
intercooler install
> From: <acroxford@h...>
> To: <BC-BFLegacyWorks@y...>
be
any
old
> > > Hi Alex
> > thinking there
the
> > wrong
> > without some
and
> > back
off
> > part of
system,
> > and really
turbo
> > with the
> > from a
is
> > low
> > such a way
straight
> > shot at the
> > > intercooler inlet?
> > Your use of Yahoo! Groups is subject to
be
any
old
> > > Hi Alex
> > thinking there
the
> > wrong
> > without some
and
> > back
off
> > part of
system,
> > and really
turbo
> > with the
> > from a
is
> > low
> > such a way
straight
> > shot at the
> > > intercooler inlet?
intercooler install
My last reply went to data heaven? This is real good info on the
intercooler install Now I can join Larry witherspoons club ONE STEP
FOWARD THREE STEPS BACK and another club I AM IN TOO DEEP TO GET OUT
NOW. All I need is a radiator,a tank, some fittings and some more
areoquip hose. I do have the Spearco Centi-Puppy pump it will do 11
gal a minute and I have an idea on the tank. Some time ago I helped
part out some cars and I saved the tank from the air suspension on a
Subaru Loyale. I am a little concerned about rust but this is one
problem that the air suspension systems did not have as far as I know.
It has brackets and could mount under one of the fenders along with my
air filter and the pump.(the engine compartment is full)
won't
> be
there
> any
> old
> > > > Hi Alex
> > > thinking there
> the
> > > wrong
transition,
> > > without some
> and
> > > back
cut
> off
> > > part of
> system,
> > > and really
> turbo
> > > with the
are
> > > from a
> is
> > > low
in
> > > such a way
> straight
> > > shot at the
> > > > intercooler inlet?
won't
> be
there
> any
> old
> > > > Hi Alex
> > > thinking there
> the
> > > wrong
transition,
> > > without some
> and
> > > back
cut
> off
> > > part of
> system,
> > > and really
> turbo
> > > with the
are
> > > from a
> is
> > > low
in
> > > such a way
> straight
> > > shot at the
> > > > intercooler inlet?
