Stank Smell Plus Loads of Moisture on Windshield
monty's legacy
So this has just started, my guess is heater core? Is there any way to get this fixed without it killing my finances? My heater and defroster still work, so it isn't in dire straits yet. A friend said this can be a 4 hourish job is that so? Also I live in MA so I really don't want to live without a heater in the winter, has anybody else had this issue and had it last for a while before giving out???
91 Lsi 180k RIP(3-19-06) Sold for $120
93 L 134ish, Bring on the Snow Baby
internetautomart
it does sound like a leaky heater core which you can try to remedy with a top leak product, however you do run the risk of screwing up other cooling system components with the aforementioned stop leak and can't even guarantee it will fix your issue.
If you can't find someone to do it relatively cheaply and you won't do it yourself then suck it up and have someone fix it for you and pay them $$
heater core labor time is 3.5 hrs
you need one, you're stuck now suck it up and git'r dun!!
94 BC w/ AWD Sold 6/25/08
92 BJ Rust bucket gone
90 BC (I think) Stripper, gone since 2k
86 GL10 Turbo 4wd, Gone since 99
monty's legacy
internetautomart
Does the "stank" smell smell like antifreeze? Cuz I wouldn't describe antifreeze's smell as stanky. Does the moisture feel a little sticky and a little greasy? That's what antifreeze feels like.
If it is a heater core leak, these types of leaks tend to get worse at an accelerating rate. I'd suggest a known-good used heater core if you can't afford a new one.
Check this out:
http://bbs.legacycentral.org/viewtopic.php?t=34328
Check this out:
monty's legacy
