engine tear down with pictures
SemperGuard
Post by SemperGuard »
evolutionmovement wrote:Good pictorial. That twin turbo exhaust setup is odd. Looks like a crosspipe connects the two headers, but only exists for pulse tuning purposes. I wonder what effect it achieves vs. two completely separate headers.
The system is a two-stage sequential. The cross pipe is there to allow exhaust to reach both turbos. If the manifolds were separate the torque, horsepower, and throttle response would be worse than stock.
But it looks like the pulses would have to travel backwards. It seems more like it's there for some kind of pulse tuning.
BXSS
Post by BXSS »
+1 for this getting sticky'd !!!!!
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
SemperGuard
evolutionmovement wrote:But it looks like the pulses would have to travel backwards. It seems more like it's there for some kind of pulse tuning.
Google a diagram, it will all make sense.
SiCkSTi04
Post by SiCkSTi04 »
what sealant is used when putting the block back together?
ciper
Post by ciper »
LOL!
The "twist the piston for removal" trick is pure genius! Can't believe I never thought of that. You have no idea the stupid things I've done to remove pistons. hahahahaha
Yes you need to use sealant on the block.
I've used Permatex Ultra Grey that couple times with no issues.
SiCkSTi04
Post by SiCkSTi04 »
whoops i meant what sealant was use to seal the block hehe
http://www.main.experiencetherave.com/s ... alants.gif
The permatex ultra grey should work fine.
