Got a tip from subychris94 the other day that he kind of stumbled on and it has worked for me everytime as it has for him. Thought I would pass it along.
If you start your engine and your lifters are making a racket, shut your engine off and then restart it. End of racket. Can't say for sure why it works, but it does. Try it.
Jeff
noisy lifters? try this
OR... If you are NA... You could have the rocker arms swapped out from a '97 2.2L...
NO more Lifters!!! All solid!!!
We had it done to my FWD and it works great. Dale at Northwest Subaru service suggested it!
smh0101 wrote:OR... If you are NA... You could have the rocker arms swapped out from a '97 2.2L...
They will work on Turbos...
Rocker geometry is the same
Kool!555BCTurbo wrote:smh0101 wrote:OR... If you are NA... You could have the rocker arms swapped out from a '97 2.2L...
I havent had any lifter issues with the turbos... only that NA...
