Hard Starting
Locked
yahoo@mintzer.com
Hard Starting
Post by yahoo@mintzer.com »
Does anyone have some suggestions why it could be hard to start my
1990 Legacy LS (non-turbo)?
I don't have the check engine light on (anymore - I had to replace
the purge control solenoid and temp sensor), I replaced the plugs,
wires, and air and fuel filter. The vacuum lines appear to be OK.
It's hard to start (I have to crank it for a few seconds and give it
gas) when the engine is "hot" and "cold". The only time it isn't hard
to start is if I start it immediately after I stop it (it starts
right up without having to step on the gas).
Also, the idle isn't very smooth.
I am planning on replacing the timing belt (it has 144K miles, I'm
the 3rd owner and I don't have the maintenance history).
Thanks.
FREE COLLEGE MONEY
CLICK HERE to search
600,000 scholarships!
http://us.click.yahoo.com/zoU8wD/4m7CAA ... /XoTolB/TM
Dave C
Hard Starting
Post by Dave C »
I had to replace my coolant temperature sensor when i first got my
Turbo, it was occasionally hard to start. That fixed it. I also
replaced the Throttle Position Sensor with a used one, and that
helped cure both a CEL and annoying hesitation.
CTS is cheap, TPS is NOT.
it
hard
> Thanks.
FREE COLLEGE MONEY
yahoo@mintzer.com
Hard Starting
I replaced the CTS too, but it didn't really make any difference (I
did check the computer and it is using the module). I "looked" at the
CEL and it looks OK to me :-) (the computer isn't reporting any
problem). I hate just replacing parts - especially when they are
expensive, but maybe I'll have to start?
Thanks for the info.
The Nissan Sentra
Everything but compact
http://NissanDriven.com
http://us.click.yahoo.com/3vsIKC/txlCAA ... /XoTolB/TM
Josh Colombo
Hard Starting
Post by Josh Colombo »
What type of gas you running in it? If you are running premium, don't.
Run 89 or 87. My 90 has issues starting/sputter on startup if I run
premium. Also may want to check MAF sensor, see if it's really dirty.
And possibly O2 sensor.
Josh Colombo
jcc189@psu.edu
of beats and rhythm" - ME
-----Original Message-----
Sent: Wednesday, August 29, 2001 12:21 AM
Subject: [BC-BFLegacyWorks] Hard Starting
Thanks.
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
FREE COLLEGE MONEY
http://us.click.yahoo.com/47cccB/4m7CAA ... /XoTolB/TM
Josh Colombo
Hard Starting
Dave, what type of hesitation are you talkin about? Is it the
"infamous" subaru hesitation, or something different.
Josh Colombo
jcc189@psu.edu
Sent: Wednesday, August 29, 2001 90 AM
Subject: [BC-BFLegacyWorks] Re: Hard Starting
it
hard
> Thanks.
Monitoring Service trial
http://us.click.yahoo.com/MDsVHB/bQ8CAA ... /XoTolB/TM
yahoo@mintzer.com
Hard Starting
I'm running regular (glad to hear I shouldn't run premium).
I did some "simple" checkes on the MAF and O2 sensors and they appear
to be OK.
I'm now leaning to my fuel injectors (see new post).
Thanks for the suggestions.
Joe
Locked
