the 91-94 usdm turbo legacy has a hitachi ecu. not a Jecs like the svx
can you read the rom on the hitachi's like you can the jecs?
has any one hacked the legacy ecu?
El_Kameleon
It's not going to happen unless your capable of tackling it yourself.
If you need programmable EM now, check out these recent threads:
http://bbs.legacycentral.org/viewtopic.php?t=35193
http://bbs.legacycentral.org/viewtopic.php?t=35093
I am working on a write up on how to use any of the plug and play EJ20G ECUs.
I beleive Doug also has a Perfect Power thread out there also.
