Sambo/anyone-
Locked
mike p.
Sambo/anyone-
Post by mike p. »
is there any way to hold the crankshaft pulley in place to get it off
besides a chain wrench or the like? maybe say by putting the car in
gear? would that do the trick? i just got my cam/crank seals and
timing belt and was just wondering if i'm absolutely going to have to
rent a chain wrench.
FREE COLLEGE MONEY
CLICK HERE to search
600,000 scholarships!
http://us.click.yahoo.com/Pv4pGD/4m7CAA ... /XoTolB/TM
daniel.wilson@db.co.nz
Sambo/anyone-
Post by daniel.wilson@db.co.nz »
I had to use a rattle gun to get mine off.
off
in
to
Josh Colombo
Sambo/anyone-
Post by Josh Colombo »
Mike if you want to get the crank bolt off that holds the pulley on, here's what you do.
If you have an auto, there is a little plastic plug just behind where the motor bolts onto the tranny, take that out, and put a big screwdriver or something in there to hold against the torque converter plate, and then get big breaker bar on that bolt. Get a friend to help. I did mine by myself, a little more tricky.
If you got a manual. Get a friend to put the car in 5th gear, and stand on the brakes. While he's doing this, you should be able to loosen the crank pulley bolt.
-----Original Message-----
Sent: Thu 10/4/2001 111 AM
Cc:
Subject: [BC-BFLegacyWorks] Sambo/anyone-
FREE COLLEGE MONEY
mike p.
Sambo/anyone-
Post by mike p. »
cool, i was just about to ask about that. thanks. now one last
thing though i am not too clear on, i haven't heard anything about
anyone first finding top dead center when they take their pulley
off, am i to believe that this is not necessary and i could cut that
out of the process or should it be done? after this i'm going to try
and quit bugging you guys, i swear...
> here's what you do.
where
converter
help.
stand
the
> crank pulley bolt.
> Josh
> From: mike p.
> To: BC-BFLegacyWorks@y...
> Cc:
> it off
> car in
> and
> have to
> FREE COLLEGE MONEY
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
FREE COLLEGE MONEY
Samuel Barrett
Sambo/anyone-
Post by Samuel Barrett »
Dude,
Go back and read my previous posts. Forget about the TDC thing. Just line up
the marks on the machine, with the ones on the belt, count teeth, adjust the
belt tensioner to the left (knees on bumper) with a screwdriver and tighten
it down, double check the marks, pull the pin on the tensioner (acutally a
small cold forged hex wrench that you have to provide), then put the rest
back together and see what happens when you hit the ignition.
Indications:
1. the car runs a little rough at first but settles down to normal after a
second or two - you did right!
2. runs like crap - you are off by one tooth, do over.
3. you get combustible fuel/air mixture filling the passenger compartment -
you used the wrong timing mark on the crank - do over.
No timing lights, no fiddling, it either runs correctly, or it doesn't.
My previous posts are pretty specific. But I'm leaving a lot of the work
(like removing fans etc.) out of those directions. So they aren't perfect,
but they should help considerably.
Tis better to ask a question, than to fuxor something up horribly. Hence,
there are no stupid questions.
-=Sambo
Sent: Friday, October 05, 2001 7:49 AM
Subject: [BC-BFLegacyWorks] Re: Sambo/anyone-
> here's what you do.
where
converter
help.
stand
the
> crank pulley bolt.
> Josh
> From: mike p.
> Cc:
> it off
> car in
> and
> have to
> FREE COLLEGE MONEY
FREE COLLEGE MONEY
mike p.
Sambo/anyone-
Post by mike p. »
cool, that's all i needed to know. thanks alot, i really appreciate
it especially now that i see i'll be doing alot of my own mechanic
work myself(expecting a new family member, and money's going to be a
little tight:). just didn't want to mess anything up by not having
it at TDC. the belt i have seems like it would be pretty hard to put
on wrong(knock on wood) because the marks are precisely at the
correct intervals. again thanks. now just have to wait for the
weather or the garage to clear, whichever comes first. :)
--- In BC-BFLegacyWorks@y..., "Samuel Barrett" <LEVATHIAN@s...> wrote:
> Dude,
Just line up
adjust the
tighten
(acutally a
the rest
> Indications:
after a
compartment -
doesn't.
work
perfect,
Hence,
> -=Sambo
> From: mike p. [mailto:ob1poor@y...]
that
try
on,
> > here's what you do.
> where
> converter
> help.
> stand
loosen
> the
> > crank pulley bolt.
> > Josh
> > From: mike p.
> > Cc:
> > it off
> > car in
> > and
> > have to
> > FREE COLLEGE MONEY
FREE COLLEGE MONEY
Samuel Barrett
Sambo/anyone-
Firstly, congratulations!
Secondly, you bought the right timing belt. Some knock off brands don't have
the marks.
Now, *MAKE SURE YOU MARK THE ORIGINAL BELT, AND THE MARKS ON THE ENGINE (w/
a grease crayon)* before you take off the original. Then you'll have a
reference to go back to just in case...
If you have the count right, the tensioner set in the proper order, the
marks lined up, and the crank bolt tightened to the right kilo newtons (see
previous posts), then everything should go just fine.
More details: When you get the tensioner off, you'll need a very small, cold
forged, hex wrench to re-set it. Oh, and a very large bench vise helps a
lot. Go *slow* when re-setting it in the vise. Just a quarter turn every two
seconds will work better than just leaning on the vise. Trust me, I busted a
very nice bench vise using cheater bars and trying to muscle it down.
Patience is the best tool with this thing. When you get it set, you'll need
to put the hex in there at a very specific manner. When you come to this
step, keep this in mind: Think about how the tensioner hangs on the engine.
Then think to yourself: how should I put the hex into the small holes so as
that I can reach in there easily and remove it (the hex that is). If you put
it in backwards you'll have to put it back in the vise and switch it around.
If you put it in too deep, the hex will prevent the tensioner from mounting
the engine - but that's easy to fix, just pull it back a little, then try
again. But if it's backwards, you'll have to do over. Don't forget about the
order in which you re-mount it I detailed in the previous post. Big time
important! If you don't get the tensioner back in there in the right
sequence - you'll have to do it all over again...
-Sambo
*'s and all caps for emphasis, not volume :o)
Sent: Saturday, October 06, 2001 10:44 AM
> Dude,
Just line up
adjust the
tighten
(acutally a
the rest
> Indications:
after a
compartment -
doesn't.
work
perfect,
Hence,
> -=Sambo
that
try
on,
> > here's what you do.
> where
> converter
> help.
> stand
loosen
> the
> > crank pulley bolt.
> > Josh
> > From: mike p.
> > Cc:
> > it off
> > car in
> > and
> > have to
> > FREE COLLEGE MONEY
FREE COLLEGE MONEY
Sambo/anyone-
It's not important, for the instructions he was giving you the piston
had to be at the top so the piston was pushing the nylon against the
head.
Dan
that
try
FREE COLLEGE MONEY
Locked
