What is Stock hp?
Saskatoon Subaru
What is Stock hp?
Post by Saskatoon Subaru »
anyone know the stock hp for a 91 SS, the one thing i have says
160Kw at 5,600rpm ------- which is 214hp at 5,600
181 Ft-lbs at 2,800
2010 Impreza WRX - 265hp
1990 Legacy 267,000km(Rebuild complete 265,423km----March 9/2008)
1991 Legacy Turbo 180,000km
Murphy
Post by Murphy »
maybe i am completely misguided here, but that doesnt sound right to me
i though for the 1st gen SS it was 160hp/tq
1990 Legacy LS, 4EAT
I remmeber it being 181 ft-lbs torque and 160hp. I thought someone dyno'ed the car stock and it makes over 160hp at the wheels :S
smh0101
Post by smh0101 »
Yup...
160hp
181lb-ft
*just checked the brochure*
BXSS
Post by BXSS »
+1 stock rating is 160HP/181TQ.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
Oh and I recall it making full power at like 3,000rpms which is awesome.
smh0101
Post by smh0101 »
It makes peak torque at 2800 rpm I believe and peak hp at like 5400.
Saskatoon Subaru
ericem wrote:Oh and I recall it making full power at like 3,000rpms which is awesome.
i thought i read something like that to but guess not.
dscoobydoo
Post by dscoobydoo »
Check my earlier dyno posts.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
James614
Post by James614 »
I'd call BS on that one..... that works out to 190ish at the crank (unless I suck at math more than I think I do), and isn't that getting awfully close to early EJ20G territory?
I dyno'd mine with relatively no mods, no I/C. LW flywheel, pullies, & a DIS-2 are about the only engine specific mods....and I was at 153.2 hp.
http://www.main.experiencetherave.com/s ... gdyno1.jpg
skid542
Post by skid542 »
Josh, I assume the above dyno run was after the conversion to AWD as you did that the same time at the turbo swap?
Lee
Yes the above dyno is after the AWD & 5spd conversion, & turbo motor swap.
Here's a dyno sheet from right after the AWD & 5spd conversion. You really can't compare the numbers due to the different dyno types.
http://www.main.experiencetherave.com/s ... cydyno.jpg
