Anyone ever experience this?
Anyone ever encounter this problem on a turbo legacy
Poor gas milage about 200miles per tank
Which is the same thing before and after a UR pulley
install
It also seems like it doesnt always want to lay the
power to the ground sometimes it picks up and goes
and other times it revs the same but its just not
being laid to the ground I personally think its some
sensor but Im not sure on what.
I have new plugs and wires, pcv valve, fuel filter,
fresh oil change, new belts, UR pulley. (Thats all
the engine related stuff Ive done recently)
Any ideas?
Do You Yahoo!?
Make a great connection at Yahoo! Personals.
http://personals.yahoo.com
Monitoring Service trial
http://us.click.yahoo.com/Gi0tnD/bQ8CAA ... /XoTolB/TM
install
Any ideas?
Do You Yahoo!?
Bad gas mileage HAAA.! (Thats not funny) Ok when I bought my car I got 8
mpg on the way home,AAAAAAAA!! come to find out that the it was only a
in town car(no highway) for about two years. I called my mechanic and
asked for a remedy, he told me to "RUN THE PISS OUT OF IT" and I did,
mileage increased slowly to 23 mpg(about a month, month an a half) but I
drive a minim of 1/2 hour to get any were! Good luck Dan
(Southwestern,WA{Brooklyn})
Another thing you could do is to reset the ECU, the ECU is a learning ECU so it learned to adjust everything based on city driving. So if you reset it, it starts the learning and adjusting period over again.
Josh Colombo
jcc189@psu.edu < mailto:jcc189@psu.edu>
of beats and rhythm" - ME
-----Original Message-----
Sent: Sunday, October 21, 2001 1:25 PM
Subject: Re: [BC-BFLegacyWorks] Anyone ever experience this?
ADVERTISEMENT
<http://rd.yahoo.com/M=213858.1650662.31 ... .tf?s=5085>
<http://us.adserver.yahoo.com/l?M=213858 ... =910873387>
Josh Colombo
ADVERTISEMENT
Someone just told me that he put 6 bottle of Fuel injection cleaner
to a full tank of gas and it improves the gas mileaga!!
Belive it or not!!! I havn't try for myself but some of my friend
does and has a little bit improve!!!
That's not good. That stuff will eat all the rubber seals and stuff if you get too much. I'm surprised the car ran.
Josh Colombo
Sent: Sunday, October 21, 2001 3:52 PM
Subject: [BC-BFLegacyWorks] Re: Anyone ever experience this?
ADVERTISEMENT
<http://rd.yahoo.com/M=178320.1681224.32 ... /yahoo-57f>
<http://us.adserver.yahoo.com/l?M=178320 ... =967469298>
Josh Colombo
ADVERTISEMENT
What is cheaper, fuelinjectorcleaner or fuel? Is it
worth it? I don´t think so. It´s better to clean the
injectors manually ones a year. (ofcourse by a pro)
/Crusher
--- Josh Colombo <jcc189@psu.edu> wrote: > That's not
> seals and stuff if
> Josh Colombo
> jcc189@psu.edu <mailto:jcc189@psu.edu>
> From: b.lam@usa.net [mailto:b.lam@usa.net]
> experience this?
> injection cleaner
> mileaga!!
> of my friend
> to:
> Your use of Yahoo! Groups is subject to
_____________________________________________________
Nokia Game kör igång igen!
Gå till http://se.yahoo.com/nokiagame för att gå med i det nya äventyret innan den tredje November.
/Crusher
> seals and stuff if
> Josh Colombo
> experience this?
> injection cleaner
> mileaga!!
> of my friend
> to:
This has always been the case with mine since I got it
4yrs ago. Has 180k on it now, and still has issues
with good power sometimes and some other time not so
good. Lately, I've noticed that the car pulls much
stronger when the gas level is at the last click or
less. Not sure what that is all about.
nue
91 legacy turbo
Message: 7
Date: Sun, 21 Oct 2001 09:40:47 -0700 (PDT)
Subject: Anyone ever experience this?
install
Any ideas?
nue
91 legacy turbo
Message: 7
install
Any ideas?
I check my ecu for codes today and I got 32 and 21
Oxygen sensor and water temperature sensor
O2 sensor from the dealer is $130
Bosch o2 sensor is $85
No name o2 sensor is $80
The bosch book only list it for 1992-1994 as being a
turbo. How do I check what month my car is? Also is
there anyone out there that knows where to get it for
cheaper? Do you think the problem I described before
is the effect of a bad 02 sensor?
John
91 sport sedan
> legacy
> install
> some
> Any ideas?
> Do You Yahoo!?
> to:
Do You Yahoo!?
John
91 sport sedan
> legacy
> install
> some
> Any ideas?
> Do You Yahoo!?
> to:
Do You Yahoo!?
Before you go and replace this stuff. What I would suggest is resetting the ECU, drive the car for a little bit, then check the codes again. If you get the same codes again, you know you have a problem with that particular sensor and it wasn't a fluke.
How many miles are on the car? The O2 sensor personally I'd just go with the dealer one. They're goin to run you around 100 bucks for a good 3-wire one. I went dealer for my 90 because there was 2 different models during the 90 model year, depending on when the car was manufact.
Josh Colombo
Sent: Tuesday, October 23, 2001 3:12 PM
John
91 sport sedan
> legacy
> install
> some
> Any ideas?
> Do You Yahoo!?
> to:
Do You Yahoo!?
ADVERTISEMENT
<http://us.adserver.yahoo.com/l?M=213858 ... =454545998>
Josh Colombo
John
91 sport sedan
> legacy
> install
> some
> Any ideas?
> Do You Yahoo!?
> to:
Do You Yahoo!?
ADVERTISEMENT
i have a 129,000 miles I'll do a reset... thats a good
idea... I'm praying though that this is the
probablem... anyone know how to check what month and
location my car was made?
> the codes again. If
> problem with that
> 100 bucks for a
> Josh Colombo
> From: Nissan-Subaru [mailto:nissans14@yahoo.com]
> experience this?
> for
> Thanks
> John
> 91 sport sedan
> > legacy
> pulley
> > install
> the
> goes
> > some
> filter,
> all
> > Any ideas?
> > Do You Yahoo!?
> email
> > to:
> Do You Yahoo!?
> to:
Do You Yahoo!?
FREE COLLEGE MONEY
CLICK HERE to search
600,000 scholarships!
http://us.click.yahoo.com/Pv4pGD/4m7CAA ... /XoTolB/TM
> the codes again. If
> problem with that
> 100 bucks for a
> Josh Colombo
> experience this?
> for
> Thanks
> John
> 91 sport sedan
> > legacy
> pulley
> > install
> the
> goes
> > some
> filter,
> all
> > Any ideas?
> > Do You Yahoo!?
> > to:
> Do You Yahoo!?
> to:
Do You Yahoo!?
FREE COLLEGE MONEY
It will be on your vin tag, It will be at the bottom of the pillar between the front and rear doors on the drivers side. Open the door and lean down and you should see it. Little aluminum plate. Will have your manufact date on it.
Josh Colombo
Sent: Tuesday, October 23, 2001 42 PM
Subject: RE: [BC-BFLegacyWorks] Re: Anyone ever experience this?
> the codes again. If
> problem with that
> 100 bucks for a
> Josh Colombo
> From: Nissan-Subaru [ mailto:nissans14@yahoo.com]
> experience this?
> for
> Thanks
> John
> 91 sport sedan
> > legacy
> pulley
> > install
> the
> goes
> > some
> filter,
> all
> > Any ideas?
> > Do You Yahoo!?
> email
> > to:
> Do You Yahoo!?
> to:
Do You Yahoo!?
FREE COLLEGE MONEY
ADVERTISEMENT
<http://us.adserver.yahoo.com/l?M=213858 ... =243328938>
Josh Colombo
> the codes again. If
> problem with that
> 100 bucks for a
> Josh Colombo
> experience this?
> for
> Thanks
> John
> 91 sport sedan
> > legacy
> pulley
> > install
> the
> goes
> > some
> filter,
> all
> > Any ideas?
> > Do You Yahoo!?
> > to:
> Do You Yahoo!?
> to:
Do You Yahoo!?
FREE COLLEGE MONEY
ADVERTISEMENT
Josh, i couldn't agree more with your comments.........
Rod.in OZ
----- Original Message -----
Sent: Wednesday, October 24, 2001 6:20 AM
Josh Colombo
John
91 sport sedan
> legacy
> install
> some
> Any ideas?
> Do You Yahoo!?
> to:
Do You Yahoo!?
ADVERTISEMENT
<http://us.adserver.yahoo.com/l?M=213858 ... =210035118>
Rod.in OZ
Josh Colombo
John
91 sport sedan
> legacy
> install
> some
> Any ideas?
> Do You Yahoo!?
> to:
Do You Yahoo!?
ADVERTISEMENT
