LSD swap???
1991legacyturbo
LSD swap???
I have a Mint 3.90 lsd rear diff,
anyone want to trade for a 4.11 lsd???
if not, anyone want to buy a 3.90 lsd??
You currently have an open 4.11 differential right? Take it apart, take the 3.9 lsd apart and swap carriers.
End result is an open 3.9 and a 4.11 LSD. I did this by myself with no special tools in my driveway (does a reverse torx driver count?). Keep everything else exactly as it was including the backlash spacers. You don't even have to loosen the pinion bolt!
1991legacyturbo
1991legacyturbo
There's no clutch pack. It's a sealed viscous coupling.
It shouldn't be too difficult once you get everything out and see how it works....but without pictures, it's a little difficult to describe.
Like they said no clutch pack. Only some of the pre Legacy Subarus had clutch based LSD. Yours is most likely viscous if not gear based.1991legacyturbo wrote:i know how to take it out, i put the new open diff in![]()
so i open it up and just swap the clutch pack??
Basically remove everything in the "back" of the differential and swap the largest internal part of one unit with the largest internal part of the other. I think there are about 12 bolts holding the ring gear to this part.
1991legacyturbo
x2ScottyS wrote:When you do this swap, can you use the old LSD axles in the new 4.11 diff, or do you have to use different axles?
i'm looking for parts. i have 4.11's that are open and i need lsd*
(*need it to fulfil my wants.)
93 legacy wagon. 5mt. awd. turbo.
99 toyota tacoma. 3.4 s/c 4x4 LT 5spd.
mexicanzero
so if i were to stick the lsd part of a diff in my diff would i still use my cv shafts or the ones meant for the lsd diff?
thanks
-Alex
thanks
-Alex
LIVE LOUD, ROCK HARD!!@
1992 Subaru Legacy SS 06 WRX TMIC TD-04 MSD coil 3" turboback H&R coils GR2 shocks fsb 20mm rsb 22mm stage 2 chip
2003 silver wrx wagon 5 spd just bought!! stock for now...
