intercooler woes
Locked
subaruracer755@cs.com
intercooler woes
Post by subaruracer755@cs.com »
heres the skinny on the MY 93-96 WRX IC fitting. the big issue is this. the 2nd water tank (small radiator cap to the right of the throttle body) needs to be moved because of the angle of the IC. i moved mine to the opposite side of the engine and made a bracket to hold it. then ran hoses to it. the second one is the angle of the dangle that you described. Yes originally i used a piece of radiator hose, but those dont hold up long against a HOT turbo outlet. i had to go online and find a 45deg piece of silicone hose and cut it to shape. its an annoying job as the IC inlet gets very close to the turbo outlet and makes fitting a pain. but past that its not that bad. but to get rid of that issue, thats why im buying a used TD04 from mr fullerton that way nothing is strained and bent.
any other questions?
ADVERTISEMENT
<http://rd.yahoo.com/M=213858.1727639.32 ... .tf?s=5085>
<http://us.adserver.yahoo.com/l?M=213858 ... =703144435>
acroxford@hypermall.net
intercooler woes
Post by acroxford@hypermall.net »
Is that TDO4 also known as a VF10 ? I have thought about one because
of the same problem you are describing. I ordered a WRX turbo from OZ
but they sent me the TDO5 and that is a bit large and I am planing on
selling it.
this. the
body) needs
opposite
it. the
originally i
HOT
hose and
close to the
bad. but
fullerton
Mark Ward
intercooler woes
Post by Mark Ward »
Interesting enough, Australia, NZ etc has the radiator tank mounted in a very different spot then North America. It is next to the power steering pump. I wonder if we could make it work on the north american motors?
Mark
ADVERTISEMENT
Your use of Yahoo! Groups is subject to the Yahoo! Terms of <http://docs.yahoo.com/info/terms/> Service.
dfullerton.screaming.net
intercooler woes
Post by dfullerton.screaming.net »
Yeah and hurry up with the money
----- Original Message -----
Sent: Monday, November 12, 2001 11:25 AM
Subject: [BC-BFLegacyWorks] intercooler woes
jason grahn
intercooler woes
Post by jason grahn »
ouch with the demands there.. I sensed no humor in your tone of type.
hehehe.. ;)
-Jason
>From: "dfullerton.screaming.net" <dfullerton@dfullerton.screaming.net>
> From: subaruracer755@cs.com
_________________________________________________________________
Get your FREE download of MSN Explorer at http://explorer.msn.com/intl.asp
intercooler woes
HE he he he no Subaruracer is a top guy. just messing The Turbos waiting
man, This has to be one of the best Groups for legacy/subarus out there,
Just to bring you up to speed on my car Legacy 2.0 uk bilstien struts
whieline springs solid drop links 22mm rear anti roll bar sti gearbox engine
tie rod mounts short shift, clutch peddle mod 17 inch my01 impreza wheels
sti 4 pot calipers trarox grooved drilled disks Mrt 3inch turbo back system
front rear strut braces, Apexi ebc Dastek unichip boost gauge home made
induction kit P1 Prodrive front seats, 98 impreza heads and TD05 to go on in
two weeks ill post some pics when i get a chance, top mounts have now gone
so ill have to get some sti ones
To: <BC-BFLegacyWorks@yahoogroups.com>
Sent: Monday, November 12, 2001 10:52 PM
Subject: Re: [BC-BFLegacyWorks] intercooler woes
> hehehe.. ;)
> -Jason
czo79@hotmail.com
intercooler woes
Post by czo79@hotmail.com »
I have a 91 Legacy turbo, US spec, with an 94 WRX EJ20 and IC, my 2nd
water tank is mounted next to the power steering pump...just thought
I'd toss that out there.
Micum
this. the
body) needs
opposite
it. the
originally i
a HOT
silicone hose and
close to the
bad. but
fullerton
StartMeUp jump starts your car's battery
using only the cigarette lighter.
$24.95 at Youcansave.com
http://us.click.yahoo.com/ELP6ED/LTTDAA ... /XoTolB/TM
Locked
