Auto to Manual conversion
Locked
radioactiveman_2
Post by radioactiveman_2 »
Hi everyone,
Just curious if anyone here has changed their auto for a manual
gearbox in a '92 Liberty/Legacy Turbo? If so, are there any trouble
spots or is it worth the trouble at all?
Jamie
legacycentral
Post by legacycentral »
I'm doing this on my 93 Touring Wagon next weekend (i hope).
Stay tuned :D
subman2001nz
Post by subman2001nz »
You need:
Clutch Master and Slave Cylinder, Clutch hoses, Hydraulic clutch
pedal and Brake Pedal. ECU. Flywheel, pressure plate and clutch
plate. A turbo gearbox with gear stick and the gearbox cross member.
Note: The Turbo gearbox and N/A gearboxes are slightly different on
the bell housing to allow for the different clutch these are Cable or
Hydraulic. Everything else on the gearbox is indentical.
I mentioned the Hydraulic type because your car in turbo and they a
more heavy duty than the N/A cable equivalent.
milehial2000
Post by milehial2000 »
You should not have to replace the ECU on US spec cars. There is a
wire that has to be cut at the ECU. It is labled AT/MT Identification
and is pin B48 #20 for the ECU.
AL(CO)
Josh Colombo
Post by Josh Colombo »
Really??
That's it? That's pretty damn cool. Doesn't the ECU get signals from the auto tranny that it won't get from the manual? Or is that what this wire does. Just tells the computer, ok don't look for this auto shit any more?
That's a very good bit of info.
Thanks Al
legacycentral
I agree, damn Al!
Kevin C
Post by Kevin C »
Lol I knew that you didn't need a new ecu but didn't know anything about the wires. Now only if I had $$$ to go about. I've been saying that for a while :(. Good luck to guys with your projects. I hope they work well. Will look forward to seeing how they turn out.
Kevin
subman2001nz
Thanks for that info. I thought there was more to it than that. I
will have to dig now for the EJ20 wiring to see if it is the same.
Dan
radioactiveman_2
Thankyou all who answered. Does anyone know if the wire cutting trick
on US spec cars is the same for Jap spec cars?
Jamie
subman2001nz
That is what I am trying to find.
Dan
legacycentral
Now that i've done the swap, i should probably do this.
How do i tell what wire is B48 #20?
Got any pictures?
Josh Colombo
Dave,
I'm assuming you're goin to do a write-up of this for legacy central. I'm
real curious how everything went, any problems you had, etc.
legacycentral
I'm currently working on it, just passed the 4000 word mark :D
It's a doozie.
ssspoon@aol.com
Post by ssspoon@aol.com »
Hey Legacycentral Dave
Did I ask what plans you have for the torque converter?
Larry Witherspoon
Torrance Los Angeles
Locked
