Compression Test With Motor Out?
Can I do a compression test on a motor that's on an engine stand? Do I just turn it over by hand with a breaker bar or could I use an impact gun?
I really doubt that bolt would snap. It's quite large. I would use the starter but I don't have a remote start and it bolts up through the tranny so that wouldn't work.
If you have or can borrow a compressor, just do a leakdown test instead.
I wouldn't trust turning it by hand or an impact wrench. Consistent RPM is a bigger part of a compression test than most realize.
I've seen quite a few people snap the hub retaining bolt on SBCs. That's a 7/16"-20 bolt, so it's no small fry either..kimokalihi wrote:I really doubt that bolt would snap. It's quite large. I would use the starter but I don't have a remote start and it bolts up through the tranny so that wouldn't work.
Don't you need a leak down test gauge and stuff for that? I have a compressor.PhyrraM wrote:If you have or can borrow a compressor, just do a leakdown test instead.
i think it could easily be done on a stand, with an air impact gun. Just start out low on the supply pressure to the gun, as in normally I run 90 psi on mine, maybe start at 50 and work up to maybe 80, taking compression readings along the way. I'd do this on the lowest setting on the gun, if it has different torque settings. build a small matrix of compression numbers for each cylinder, and you'd get a good number if you average them (and watch for trends etc).
that being said, I haven't done this on a Subaru engine, even though I have one on the stand right now. the heads are gone and I'm re-ringing/honing it anyways, so I'm not that interested in what the compression was before.
12 Outback 3.6R Limited
94 Leg LS wag AWD, sold
93 Leg L wag FWD, sold
06 LGT 5EAT, project
