<http://www.avoturbo.com/graphics/avoemail.gif> Latest News. <http://www.avoturbo.com/graphics/japemail.gif>
Steel Head Gaskets.
Virtually indestructible dual-steel head gaskets to suit high performance turbocharged engines.
When an engine running high boost, high compression or both is ‘pushed’ hard, it often suffers from blown head gaskets. Steel head gaskets are a positive alternative.
Too often an engine builder is faced with the often very time consuming and expensive option of ‘sealing’ an engine with custom-manufactured rings or steel head gaskets. Fortunately, through AVO turboworld expanding their amazing range of special high performance hardware to include a number of super duty dual-steel head gaskets for most popular contemporary turbocharged engines, locating a suitable part no longer needs to be a concern.
Each gasket consists of twin reinforced competition quality stainless steel plates; a highly desirable feature as it allows for significant expansion (typical of extreme temperatures) without fear of blowout or leakage. Furthermore, the steel gaskets can be re-used; they bolt straight in and don’t require re-tensioning after run in.
AVO’s exciting new gaskets are available in a range of thicknesses including 1.0mm, 1.2mm, 1.4mm, 1.6mm and 2.0mm and are priced from $500.
These almost indestructible dual-steel head gaskets are available either from AVO or through their comprehensive Australia wide dealer network. Call AVO for details.
<http://www.avoturbo.com/html/news/pdavo ... askets.jpg>
AVO is located at 57 Taunton Drive, Cheltenham. Victoria. 3192
Phone: (03) 9584 4499 Fax: (03) 9584 4008.
Email: avo@bigpond.com Web Site: www.avoturbo.com
Larry Witherspoon
Torrance (Los Angeles)
larry.d.witherspoon@boeing.com
ssspoon@aol.com
ADVERTISEMENT
<http://rd.yahoo.com/M=220467.1906512.33 ... FxYdfY6Rk3>
<http://us.adserver.yahoo.com/l?M=220467 ... =402404614>
Head Gaskets for Rod's Megaboostzilla
