wrx brake swap
wrx brake swap
when i swap the stock brakes on my 1990 legacy out for wrx brakes, should i get a wrx master cylinder and/or brake booster? or will my stock ones do fine with them?
1990 L, 5mt, awd
dropdfocus
You'll be fine with your stock parts when installing the WRX calipers/brackets. Getting yourself a master cylinder brace helps under heavy braking. These typically mount off the side of the strut tower, but I've seen them mount straight down to the unibody frame rail.
Jason
dropdfocus
Does your 1990 have ABS?
