EJ25D, '98 2.5RS, ~ 2 3/16 x 1 1/4
Notice the socket clearly does not fit in the EJ25D head.
Don't have a set to measure. Supposedly they are the same basic casting as the EJ25D heads, but with larger ports. There is a good thread on Nasioc, butI figured I'd throw these up here because these are the commonly discussed heads on LC.
Which car is an EJ20K from and which one is the EJ20H from? I have a twin turbo 95 motor, which version is that?
EJ20H is Early twin Turbo Legacy. I *think* EJ20H is very close to EJ20G WRX heads.
Alright so I have an EJ20H motor and I also have a spare set of EJ20G or EJ20K heads.
Thanks jake. I guess you didn't notice but I sent you 2 pms about which heads they were and the differences between the heads but never got a response. That was a while ago.
So, which heads should I use? The EJ20G or the EJ20H?
