Fuel gauge is broken.
Burnera
Post by Burnera »
It's only correct when the car is topped off with gas. As soon as a little has been used, the needle goes all over, usually dropping to negative as a lot of throttle is applied. Most of the time the needle just lays there at negative.
I don't know where to begin fixing it. I don't actually know how the gas gauge works, lol.
I'm a little tired of keeping track of mileage and guessing how much further i can go.
There is a product called techron I believe? Dump it in your tank and it should clean the sensor.
If that doesn't work, you will need to replace one or both of the fuel senders. After the issues I went through, I'd suggest replacing both. Here's some more info and pictures.
http://bbs.legacycentral.org/viewtopic. ... ight=gauge
Burnera
Post by Burnera »
Thanks for the info.
I know the primary sender is under the fuel tank hatch with the fuel pump...where is the sub sender?
There's another hatch directly on the other side of the tank.
