Chips
Locked
Doug Hancock
Chips
Post by Doug Hancock »
Any body know about computer chips. I was thinking of installing one. This is the one I was thinking of http://au.powerchipgroup.com/chips/chip.asp?cid=Sub0014.
Regards Doug
Newcastle (Australia)
ADVERTISEMENT
<http://rd.yahoo.com/M=215002.1990895.34 ... 000239/R=1>
<http://us.adserver.yahoo.com/l?M=215002 ... =530624735>
Josh Colombo
Chips
Post by Josh Colombo »
I'd be curious to how they claim a certain hp for the different chips.......ProECM makes a chip.....I was talking with a guy at suby sports and seemed pretty good.....makes the car steer away from the base fuel maps.....changes how the computer learns.
Josh Colombo
<mailto:Josh@surrealmirage.com> Josh@surrealmirage.com **NEW**
of beats and rhythm" - ME
-----Original Message-----
From: Doug Hancock [mailto:Doug_hancock@optusnet.com.au]
Sent: Sunday, April 07, 2002 87 AM
Subject: [BC-BFLegacyWorks] Chips
Regards Doug
ADVERTISEMENT
<http://us.adserver.yahoo.com/l?M=215002 ... =923952085>
milehial2000
Chips
Post by milehial2000 »
The best way is to Dyno the chip and then do road tests that is what I
did when I designed the chip that ProEcm is making a knockoff of. You
might want to hang on for a bit I am going to Dyno a much improved
version of it this week.
AL(CO)
> Josh
> Josh Colombo
> <mailto:Josh@s...> Josh@s... **NEW**
> From: Doug Hancock [mailto:Doug_hancock@o...]
> To: BC-BFLegacyWorks@y...
> Regards Doug
> ADVERTISEMENT
<http://rd.yahoo.com/M=215002.1990895.34 ... upweb/S=17
05064983:HM/A=1000239/R=0/*http://ads.x10.com/?bHlhaG9vaG0xLmRhd=10181
84811%3eM=215002.1990895.3471383.1261774/D=egroupweb/S=1705064983:HM/A
=1000239/R=1>
<http://us.adserver.yahoo.com/l?M=215002 ... 1774/D=egr
oupmail/S=1705064983:HM/A=1000239/rand=530624735>
> BC-BFLegacyWorks-unsubscribe@e...
> zZz
Buy Stock for $4
and no minimums.
FREE Money 2002.
http://us.click.yahoo.com/k6cvND/n97DAA ... /XoTolB/TM
Josh Colombo
Chips
sweet,
Yeah I'll hold off.....if I can buy it directly from you.....I'd sooner give you the business. Do you know how the Proecm chip goes about changing how the computer thinks? or is that a heavily guarded secret?
Thanks Al
josh
Josh Colombo
Josh@surrealmirage.com <mailto:Josh@surrealmirage.com> **NEW**
From: milehial2000 [mailto:acroxford@hypermall.net]
Sent: Sunday, April 07, 2002 5:16 PM
Subject: [BC-BFLegacyWorks] Re: Chips
AL(CO)
> Josh
> Josh Colombo
> Regards Doug
> ADVERTISEMENT
=1000239/R=1>
> zZz
Buy Stock for $4
and no minimums.
FREE Money 2002.
milehial2000
Chips
What I am going to have should be pretty good and It should see the
dyno this week. The answer to both questions is yes.
AL(CO)
> sweet,
secret?
> Thanks Al
> josh
> Josh Colombo
> Josh@s... <mailto:Josh@s...> **NEW**
> From: milehial2000 [mailto:acroxford@h...]
I
You
> AL(CO)
> > Josh
> > Josh Colombo
> > Regards Doug
> > ADVERTISEMENT
> =1000239/R=1>
> > Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service
Buy Stock for $4
and no minimums.
FREE Money 2002.
rodeddy
Chips
Post by rodeddy »
Doug,
i have a chip installed in my RS Turbo. Excellent. Can also have a
switch installed inbetween so as to be able to run on std ecu setting
if needed. A guy here in sydney makes them. Max boost in cold
weather under full load is 17psi. You will need to already have a
good full 3" exhaust and free flowing air inlet for the chip to
perform at its best. This is what the chip is tuned to. If you like i
can send you some details.
please forward your email address to me.
regards, rod melrod@optusnet.com.au
--- In BC-BFLegacyWorks@y..., "Doug Hancock" <Doug_hancock@o...>
one. This
> Regards Doug
Buy Stock for $4
and no minimums.
FREE Money 2002.
milehial2000
Chips
Hey Rod,
What is the compression ratio on Your RS turbo? I am in the process
of incorporating a boost mod into a chip. I have been running 15lbs on
my EJ22t for a month now with no ill effects. The most we have ever
run was 23lbs but that was with an upgraded turbo and large front
mount intercooler and mostly for 1/4 mile runs at the track. Anyone
have any input?
AL(CO)
--- In BC-BFLegacyWorks@y..., "rodeddy" <melrod@o...> wrote:
> Doug,
setting
i
> regards, rod melrod@o...
> one. This
> > Regards Doug
Buy Stock for $4
and no minimums.
FREE Money 2002.
jason grahn
Chips
Post by jason grahn »
Al-
What is the size of the turbo running 15psi? intercooler? injectors?
exhaust? what are you using for boost control?
(what exactly do you want input on?) =)
-Jason
>have any input?
>AL(CO)
_________________________________________________________________
zQz:
http://photos.msn.com/support/worldwide.aspx
Buy Stock for $4
and no minimums.
FREE Money 2002.
milehial2000
Chips
It's the stock IHI VF11 with a factory water to air intercooler from a
European Legacy the stock injectors a Super Sprint ss 2/1/2" exhaust
plus a cold air intake. Where I live is about 5000' above sea level.
The boost control is an electronic type that I made and it holds right
at 15lbs right now. I figured if the US WRX can run this level of
boost why not me? I have a better intercooler. What I wanted is some
input on is what other people are running and the results. ( I just
can't see paying $300-400 for a boost controller).
AL(CO)
--- In BC-BFLegacyWorks@y..., "jason grahn" <jgrahn555@h...> wrote:
> Al-
> -Jason
on
> >have any input?
> >AL(CO)
> zQz:
Buy Stock for $4
and no minimums.
FREE Money 2002.
rodeddy
Chips
Post by rodeddy »
std compression on the RS Liberty is 8.0:1
the turbo is a IHI RHB52 which easly handles 17/18 psi. same as the
early WRX turbo, ie TD05. Then the wrx went to small turbo's from
1996 on....
Rod .in OZ
> Al-
injectors?
> -Jason
15lbs on
> >have any input?
> >AL(CO)
> zQz:
Locked
