ebay link
Hi, I plan On buying this kit. Does it look to be the correct one? The pump looks to be OEM and it is made in Japan. I will be using all those parts, and get the crank and cam seals from my dealer. It is for my 94 SS.
N/A 2.2L timing kit and water pump work with turbo 2.2L?
The timing kit will work, but the pump won't...it only has one outlet, the turbo pump has two.
http://www.slodriveracing.com
-And more!
-And more!
ha well there all due eventually. Find any good kits yet?
Found this one
ebay link
I guess ill get this kit and i can get the pump from autpartsway for $90. Says made in Japan and the blade looks OEM style.
Found this one
ebay link
Wait a second that second port is on the outside correct and it goes to the turbo or something? That hose was really wet. Maybe it is what is leaking. The timing covers are dry. Need to look into it tomorrow again. Going to order the short hose.
Please read the rules regarding posting long ebay links. Information in the rules thread shows how to change the link into a clickable word.
http://bbs.legacycentral.org/viewtopic.php?t=34486
