valve gasket replacement pics
Post by SILINC3R »
did the valve cover gaskets today. took like 3 hours to clean and put new gaskets on. pretty easy to do. help with some problems i had. hoping to see if it well help the leaky oil problem.
SiCkSTi04
Post by SiCkSTi04 »
nice work there. what gasket brand did you use?
SLODRIVE
Post by SLODRIVE »
Those look like Fel-Pro gaskets...IMO the best there are. Nice job Tony.
http://www.slodriveracing.com
-And more!
Post by SILINC3R »
thanks and yea they are Fel-pro, good eye :D
Bdub
Post by Bdub »
Great job!
Did you replace the 6 rubber washers around the covers as well?
Those harden up over time due to the constant heat they are under, and eventually leak.
Through The Generations...
91 SS 4eat
95 LSi 4eat- Sold
07 2.5i 5mt- For Sale
13 STI Sedan
jp233
Post by jp233 »
now that the covers and the gasket mate area is so clean, you'll be able to easily see that your cam seals are leaking :)
12 Outback 3.6R Limited
94 Leg LS wag AWD, sold
93 Leg L wag FWD, sold
06 LGT 5EAT, project
Post by SILINC3R »
yea i replaced the gromets. they had harded up.
yea when i get the seals done my car when be awesome :-D
The grommets usually are the culprits for valve cover oil leaks.
