Info on the idle air control valve
Locked
milehial2000
Post by milehial2000 »
The two terminal valve was found only on the '90 models in '91 and
up the three wire valve was used. From what I can remember this valve
works on what is called PWM (pulse width modulation) the center wire
is at 12 volts and the ends are switched with a signal that pulses
from 12 volts to ground the longer the ground pulse the more the valve
is pulled in that direction.
AL(CO)
Buy Stock for $4
and no minimums.
FREE Money 2002.
http://us.click.yahoo.com/k6cvND/n97DAA ... /XoTolB/TM
Josh Colombo
Post by Josh Colombo »
Al,
That sounds about right.....I've heard a couple discussions about it using a duty cycle as well. Which the PWM could be what they were talking about.
Josh Colombo
Josh@surrealmirage.com <mailto:Josh@surrealmirage.com>
of beats and rhythm" - ME
-----Original Message-----
From: milehial2000 [mailto:acroxford@hypermall.net]
Sent: Monday, April 22, 2002 108 PM
Subject: [BC-BFLegacyWorks] Info on the idle air control valve
AL(CO)
Buy Stock for $4
and no minimums.
FREE Money 2002.
http://us.click.yahoo.com/orkH0C/n97DAA ... /XoTolB/TM
milehial2000
They call it duty cycle when it's refered to in percentage of time on
and off so that's it. A scope is needed to see it They give a voltage
in the manual and that's a rather inaccurate but probably close
enough.
--- In BC-BFLegacyWorks@y..., "Josh Colombo" <josh@s...> wrote:
> Al,
talking about.
> Josh Colombo
> Josh@s... <mailto:Josh@s...>
> From: milehial2000 [mailto:acroxford@h...]
> To: BC-BFLegacyWorks@y...
valve
valve
> AL(CO)
> BC-BFLegacyWorks-unsubscribe@e...
> Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
Buy Stock for $4
and no minimums.
FREE Money 2002.
Locked
