Easy to convert turbo trans to cable push clutch?
				94.GT.Wagon
Possibly found a 92 turbo trans for my 94 non-turbo Legacy.  Is it possible and more importantly is it easy to switch to a cable push clutch?  Thanks!
							Todd
2002 Legacy GT Wagon 2.5/5mt
1999 Legacy Outback Limited Wagon 2.5/4eat(wife)
1998 Forester S 2.5/4eat
1972 Buick Electra Limited 455/TH400
1988 Jeep Grand Wagoneer 360/TF727
No, it can't be done.
				thehookeup
I have done it. I drilled a hole for the pivot ball. it took a lot of measuring and patience. Its really not worth it. if you really really really want a push type clutch on a turbo(pull type) tranny. There are some companies that sell kits to do so. But they are all for double and triple disc clutch setups.
Its just not really worth it
http://www.vividracing.com/catalog/carb ... 33828.html
http://carbonetic.nl/match/usa_subaru.html
-93  2.2T (RIP), 93  N/A best car on earth.
-00 legGT, 18" PIAA sport mesh wheels, front/rear Rallitek sways, lowered whitelines, coming soon: 2.5L sti internals, 20g heads P&P, twin charged. motor is almost ready to go in.
Andrew
Andrew
				94.GT.Wagon
Or you could convert your throwout system to hydraulic, which has also benn done. But again, a lot of work.
				94.GT.Wagon
				92ss satinsvoice
its an easy swap. get your self a set of turbo pedal assembly complete with the clutch master cylinder and line.
your not talkin about changing the tranny are you from pull to push are you? that requires changing the bell housing. that would be a waste of time.
Andy
94 L n/a 5spd, Rip
91 ss champagne - Rip
88 Leon GL Hatchback - DD
						94 L n/a 5spd, Rip
