Just bought a legacy, never seen this before.
Hello all, I bought a 91 legacy wagon last week, 5spd, N/A, lots of rust, cat piss smell inside, but runs perfect for $325.00. My intentions with this car are not to restore it to perfection, but simply to drive the hell out of it, the looks don't bother me for now. The thing that got me though is: when I got it home and found the oil level about an inch above the full mark, I immediately drained the excess oil out and noticed that the drivers side axle was not there. Passenger side was intact and looked ok, but WTF?. I drove the car around before buying it, seemed ok. My question to whoever reads this, why would someone do this? (I'm hoping too poor to replace a noisy cv joint)
I'm hoping that I can simply put an axle in and be fine, but I"m scared that this may be masking a bigger problem. Also, wouldn't this overstress the center diff?
thanks in advance.
thanks in advance.
i would say if you were able to drive it you should be able just to put one in and it should be fine. good luck though
A factory 5sp has a constant 50/50 f/r torque split I think. So it may have just been rwd and spinning that missing alxe output in the front.
Raise the front of the car and see if both axles turn independently.
Was the outer joint installed on the wheel hub? Without that, the bearing would have fallen apart?
^^^^Was the outer joint installed on the wheel hub? Without that, the bearing would have fallen apart?
Next test: with the front wheels off the ground (and the car on jackstands) will the axles (or one stub, in this case) turn independently of each other?
