Cheap FCD
Post by SubaruNation »
yeah i gotta organize myself i will get one up later w/ teh part number
Grayguy
Post by Grayguy »
^ thank you VERY much. greatly appreciated
92' SS: SOLD
The $4 Fuel Cut Defender Check valve of magic looks like this:
no part number as i am tired but just imagine looking for this, they have it at napa and its cheap and works.
How 'bout an application then?
beatersubi wrote:How 'bout an application then?
er... define your question for me a lil' better i guess and i can help :)
Grayguy
Post by Grayguy »
awesome! I'll see what I can find tomorrow at Napa. If I find a part # I'll post it up here
92' SS: SOLD
What vehicle is it intended for, and what function does it serve on that vehicle?
Vehicle: growler soob
Function: fcd
it's just a check valve
A1Fiddler
Post by A1Fiddler »
'92 Legacy Sport Sedan - EJ22T, 4EAT, AWD - Snorkle Delete, Custom Grounding, 3" Catless TBE.
yep supposed to work. you might have to switch it out every so often, i know mine started to die after awhile.
i wouldn't recommend running more than 12 pounds, and make sure you have this and an intercooler.
morgie
Post by morgie »
Hi guys, been a while ! :P
I've restored the links in the first post to the gallery, that way it should be good forever :P
morgie
'98 4Runner V6 Manual 4x4.
Good deal!
Thanks Morgie.
hmm, well i guess this would explain why my legacy dies every so often now...
jdmellor28
Post by jdmellor28 »
hummm , if you would not want to run more than 12 psi why do you need this ? my car hits fuel cut at 15psi ...
jdm jeffrey
photos : http://s135.photobucket.com/albums/q140/jeffreydm28/legacy/
asc_up
Post by asc_up »
Your car probably hits fuel cut by the time you hit 15 PSI. The car 'initiates' its fuel cut countdown at 13 PSI, and if 13+ PSI is held for more than 3 seconds THEN you experience fuel cut.
So what's probably happening is you start boosting, you hit 13 PSI and the fuel cut countdown begins, three seconds go by and fuel cut occurs right when you see 15 PSI on your boost gauge.
jdmellor28
ok good deal , now i need more info on this fcd . and photos so i make sure to plumb it in there right !
jdm jeffrey
jdmellor28
if anyone has photos of this mod with a manual boost controler installed also i would love to see the photos so i can get it right on my car !
jdm jeffrey
turbonator
Post by turbonator »
Pics Please.
jdmellor28
I have some pics, i did run this for a while, its ok but i think the MPG goes down ...
i took mine out because when i turn my boost up my clutch slips.
but im in class .. i will post some pics later when i get home
jdm jeffrey
darkcrave
Re:
Post by darkcrave »
Auto Zone
Part Number: 47150
SubaruNation wrote:The $4 Fuel Cut Defender Check valve of magic looks like this:
Tune
TMIC
Fuel
Taillight
TurnNburn
Re: Cheap FCD
Post by TurnNburn »
Sweet. Thanks for looking that up. Could you report back and confirm weather or not your gas milage changes?
1990 NA 2.2 Open Light rally car
darkcrave
Re: Cheap FCD
Post by darkcrave »
Hey turn was that your SS on craigslist? So far I had I on for about 5 miles boosting 16psi without any fuel cut. Mpg I have no idea yet? I'm thinking no beause I'm boostimg so muh now
Tune
TMIC
Fuel
Taillight
Re: Cheap FCD
Omg from the dead!
Your adding pressure, and presumably more fuel in your motor when taking this route so it really depends on how you drive.
darkcrave
Re: Cheap FCD
Post by darkcrave »
Lmao who cares its a 4$ fcd that's works 100%
Tune
TMIC
Fuel
Taillight
Re: Cheap FCD
isn't it letting meter'd air out tho? which would mix up afrs.
