My 93 legacy L wagon seems to be spewing something out of the tailpipe, after just a few days of being clean, a black sooty, slightly oily dust/film develops on my tailgate. I'm wondering what the cause of this could be and if I should be worried? The car does have a good oil leak coming from the front crank seal, and oil does drip on the exhaust and burn, the smell is very apparent. There is however no white or black smoke coming from the tailpipe, unless it is below freezing, in which case I'll get a little of what seems like normal thin white exhaust visible. Any thoughts on what could be causing this, if I should be worried and how to fix it? Not sure if this should be in engine or exhaust, so it is posted in both.
							What's this oily, sooty crap on my tailgate?
1993 Legacy L AWD 5-sp wagon
						Is the inside of the tailpipe oily? If so, there's your source. Check your PCV valve.
If not, it's likely from the engine leaks.
The oil mists at speed, and the flat back of the wagon creates a low pressure area that sucks oil & dirt onto the surface.
Jerry
Got any pics of how much?
For example, I notice the back of my wagon always gets black/dirty quickly after I wash it. Yes, it's still raining in Seattle so I suppose it could be from all the dirty highway water too. I think it's a combo of the design of the wagon to just catch crap there.
'11 WRX Limited
'94 TW | R.I.P.
				thehookeup
Leaking fluids can deposit themselves on the back of the car at speed.
Please only post your question in one forum.
I will move the other posts over here.
