specs on stock 22T valve springs...
logan9691
Post by logan9691 »
anyone know what the specs are and has anyone put in aftermarket ones? what do you want in aftermarket valve springs and whats the advantage?
Stronger valve springs will better resist valve float @ higher rpm but cause more and faster wear to the followers.
logan9691
Post by logan9691 »
ok thank you :)
what is a good place to look for aftermarket springs?
An engine parts store?
