I know this is probably a long shot, but would anyone happen to know the factory ignition dwell times for the diamond or even hitachi coil pack?
Also, I'm looking for the injector injection timing.
I need a stock car and an oscilliscope...
Factory ignition dwell times & injector injection timing
Got some info from Fineline Imports on settings they use for the Impreza with the same coil setup.
The injector injection timing they use is 400 deg BTDC
Also, I got the injector deadtimes for the STi yellow side feed injectors.
Code: Select all
6v 7v 8v 9v 10v 11v 12v 13v 14v 15v
10 10 8 7 4 3 3 3 3 3 ms
Code: Select all
6v 9v 12v 14v 16v
7.66 2.69 1.37 1.06 0.75 ms
Not too bad at normal voltages, but off quite a bit at lower voltages.
Code: Select all
Voltage Deadtimes (ms)
6 3.490
7 2.810
8 2.273
9 1.864
10 1.563
11 1.360
12 1.209
13 1.101
14 1.000
15 0.940
