Issues - Part II
Locked
formview
Issues - Part II
Post by formview »
The valve tap stopped as suddenly as it started. I'm, thinking that
maybe there was some gunk in the engine. Is it a good idea to flush
the engine?
The dripping water didn't look like condensate, so I checked the
bolts at the thermostat housing. They didn't seem completely tight.
Maybe the water was flowing from the thermostat housing, along the
oil pan, and down onto the cross member? The car is parked on a
slight hill. I'll see if the water leak stops.
I have two new problems.
When I'm turning left at very slow speeds (parking lot speed), I can
hear and feel a chatter/vibration (1-3 seconds) coming from the front
(sometimes). I feel it with the brakes on and brakes off (may be
worse with the brakes on). Any ideas?
How much of a pain is it to fix the blower system? Sometimes when I
turn on the vent or A/C the air doesn't come out of the vents (it
comes out of the floor or the defrost vents). Sometimes the fan
doesn't come on at all.
Thanks.
Will You Find True Love?
Will You Meet the One?
Free Love Reading by phone!
http://us.click.yahoo.com/Deo18C/zDLEAA ... /XoTolB/TM
Rod
Issues - Part II
Post by Rod »
When I'm turning left at very slow speeds (parking lot speed), I can hear and feel a chatter/vibration (1-3 seconds) coming from the front
........does this only happen when steering is on full lock and turning, if so probably your CV joints are worn... are the protective boots in good condition...? check the other side by turning full lock the other direction and check for noise. If worn you will hear a grind or a clicking....
perhaps your blower relay is on the way out.....
cheers, Rod ..in oz
----- Original Message -----
Sent: Thursday, June 13, 2002 1:23 PM
Subject: [BC-BFLegacyWorks] Issues - Part II
the engine?
Thanks.
Kam
Issues - Part II
Post by Kam »
Ball joint - probably need a new driveshaft
Sent: Thursday, June 13, 2002 7:59 AM
Subject: Re: [BC-BFLegacyWorks] Issues - Part II
cheers, Rod ..in oz
the engine?
Thanks.
formview
Issues - Part II
Post by formview »
front
It doesn't have to be on full lock. I did check the CV boots and they
look OK. I'll check full lock turning on both sides and see what it
sounds like.
> cheers, Rod ..in oz
I hate to have to guess with electrical stuff (because you can't
return the part once you purchased it). Do you know how I can check
it before I go out an buy a new one?
> From: formview
> To: BC-BFLegacyWorks@y...
that
flush
> the engine?
tight.
the
> Thanks.
> BC-BFLegacyWorks-unsubscribe@e...
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
formview
Issues - Part II
Post by formview »
You think I need to replace one or both of the front axles (I only
have front wheel drive)?
Kam
Issues - Part II
Post by Kam »
Impossible to tell without looking at it and driving around. Chances are just one driveshaft. You need to keep an eye out on the cv gaitor/boot that goes around the cv joint.
Sent: Thursday, June 13, 2002 2:14 PM
Subject: [BC-BFLegacyWorks] Re: Issues - Part II
Rod
Issues - Part II
Post by Rod »
how do the ball joint and the driveshaft have anything in common.... do you mean the CV joint...?
if ball joint is worn it wouldn't make any difference whether the steering is turning or not....
cheers, rod
Sent: Thursday, June 13, 2002 11:14 PM
Kam
Issues - Part II
Post by Kam »
sorry - yes, I mean cv - was programming at the same time...
Sent: Friday, June 14, 2002 2:29 AM
Subject: Re: [BC-BFLegacyWorks] Re: Issues - Part II
cheers, rod
formview
Issues - Part II
Post by formview »
I guess as long as it doesn't have a catastrophic failure without
more severe symptoms I can just watch the CV boots and see if it gets
worse, thanks.
Free $5 Love Reading
Risk Free!
http://us.click.yahoo.com/3PCXaC/PfREAA ... /XoTolB/TM
devin kundla
Issues - Part II
Post by devin kundla »
i need to replace the cv joint in my car soon... the boot has a crack in it and the car is starting to vibrate when i make sharp turns... anyone know how much this will cost me? thanks.
Sent: Friday, June 14, 2002 6:41 AM
cheers, rod
Locked
