WRX springs
Locked
Matthew Reese
WRX springs
Post by Matthew Reese »
Will 2002WRX springs fit in my '91 Legacy Turbo?
_____
zQz: Click Here <http://g.msn.com/1HM1ENCA/c156??PI=44318>
ADVERTISEMENT
<http://rd.yahoo.com/M=178320.2150041.36 ... /yahoo-79f>
layank54
WRX springs
Post by layank54 »
--- In BC-BFLegacyWorks@y..., "Matthew Reese" <carmat76@h...> wrote:
> matthew..you will need to measure the rear top of the springs..90-
91 legacys have rear springs that are smaller diameter at the top
than the bottom.the front springs are the same but the rears are
different. i have been through this on my 90wagon and 91t-sedan. the
problem is that the strutmount body area at the top is smaller and
the larger spring hats will not fit in the smaller space.i found this
out by trial and error...whiteline does make 90-91 specific
springs,mrt used to as i have a set of the yellow springs mated to
agx's..i am waiting on a set of blue whitelines for my turbo sedan to
arrive stateside from mrt. who knows why subaru chose to hold over
the smaller rear strut tower for the 90-91 but it makes for a big
p.i.a. for all of us early legacy owners.you could find out about the
wrx springs by asking a dealer,mrt or spo etc. to measure the tops of
the rear springs and compare with the dimension of the bottom...if
they are the same dimension it is a newer version...if i remember
correctly 90-91 rear spring tops are about 4-7/8"...a lot smaller
than the bottom of the springs..i will measure the set i have and
post it later..david
Free $5 Love Reading
Risk Free!
http://us.click.yahoo.com/Pp91HA/PfREAA ... /XoTolB/TM
Douglas Hancock
WRX springs
Post by Douglas Hancock »
Yeah there are two sizes for the rear between 89-94 (series 1 & 2). The springs on the series 2 known as the facefift model has a larger dia spring.
-----Original Message-----
Sent: Friday, 5 July 2002 12:52 AM
Subject: [BC-BFLegacyWorks] Re: WRX springs
Your use of Yahoo! Groups is subject to the Yahoo! <http://docs.yahoo.com/info/terms/> Terms of Service.
Josh Colombo
WRX springs
Post by Josh Colombo »
Thanks for all the info David,
Question.......can you retro-fit the 90-91 legacy rear springs with the
92-94 springs and top mounts? Or is there a physical size limitation on
the 90-91 legacies. I would like to get sti top mounts, but I don't
know if they're goin to make top mounts for the 90-91 legacies.
Any info/comments would be great.
Josh Colombo
Josh@surrealmirage.com <mailto:Josh@surrealmirage.com>
of beats and rhythm" - ME
Sent: Thursday, July 04, 2002 9:52 AM
Will You Find True Love?
Will You Meet the One?
Free Love Reading by phone!
http://us.click.yahoo.com/ztNCyD/zDLEAA ... /XoTolB/TM
Z1Auto@aol.com
WRX springs
Post by Z1Auto@aol.com »
Josh - yes you can do that.
The part numebr for the GC8 Sti group N strut tops and the Legacy BC chassis
arwe the same, and they will allow you to use any Impreza GC8 spring
Josh Colombo
WRX springs
Adam,
You read ciper's post in the legacy forum?
http://forums.i-club.com/forums/showthr ... 825&pagenu
mber=2
Can someone measure the upper diameter of the rear springs when they
take them off?
The incorrect rear springs I received from whiteline are so large They
wont even fit in the upper wheel well no matter what spring seat I have.
The person I'm working with at Whiteline told me these are the correct
springs for the turbo.
I told him the approximate diameter of my rear springs (3.5 at top 4.5
at bottom?) and he said that I need the FWD springs.
He said that since my car originally had air suspension and that I had
converted it to standard is where the problem arose. Except that I KNOW
I'm using the 4wd suspension, I mean the upper spring seats have "4wd
only - OUT" indented in the metal .
It seems that from the limited research I have done that the first year
of turbo legacy uses the same small spring while the later years use the
larger spring. I don't know how accurate that is though.
Kinda sucks, I placed the order for these springs at the beginning of
April and as of now they still are not installed
According to what he says....they "physically" won't fit in the
fenderwell. Now I'm not sure if it is different due to BF chassis vs.
BC
I've got springs for my car on order......so we shall see how things end
up.
There really does seem to be a bit of discrepancy among vendors,
dealerships, tuners out there for the old gen legacy as to what will
fit, and what will not.
This group has been very helpful in educating me.
Josh Colombo
Sent: Friday, July 05, 2002 54 PM
Subject: Re: [BC-BFLegacyWorks] Re: WRX springs
chassis
Locked
