Educate me
magicmike
Educate me
Post by magicmike »
OK so I'm not too proud to say that I have no clue about suspension componants. I've been reading all the posts in the sticky and I think I need an even more stepped back explanation. Could someone please identify all of the parts? As I read through I hear, struts, springs, perches, and top hats. I read through this stuff and cannopt get a clear picture of what the hell I need lol. I understand that you have a strut that sits inside the spring and that the perches and top hats have something to do with the mounting at the top but I'm still confused.
I only ask because I'm going to start to browse around for some oem wrx parts over on nabisco and I'd like to know what would fit and what I'd need before hand. I'd be ok with the same ride height or if it was lowered like an inch or so.
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
gijonas
Post by gijonas »
Made this up real quick,my contribution to the forum LOL.
asc_up
Post by asc_up »
Perfect.
magicmike
Post by magicmike »
ok thanks! Any suggestions for the cheapest route to upgrade?
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
SLODRIVE
Post by SLODRIVE »
http://www.slodriveracing.com
-And more!
jamal
Vendor
Vendor
Post by jamal »
I've done pretty well with cheap. I'd rather have a more expensive suspension but it works for me.
Lets see:
1st set of 04 sti suspension : $500
ALK: $200
20mm front swaybar: $50
18mm rear swaybar and stuff: $100
Endlinks: $200
Camber bolts: $10 used
That got me a pretty fun setup.
For the new car I bought a fresh set of sit suspension for $140 and got some swaybars in exchange for labor. It's really great with a lot of negative camber up front.
What is ALK again? I forget.
Do you have a non turbo car? I thought the SS comes with 18mm or 19mm swaybars to begin with?
RJ93SS
Post by RJ93SS »
this is about as cheap as you can get as far as struts only go
http://bbs.legacycentral.org/viewtopic. ... highlight=
i, like yourself knew nothing before i started this, but with help from the board and just going at it, it's about as easy as changing brake pads.
once you get it apart, it is really simple.
good luck
asc_up
Post by asc_up »
kimokalihi wrote:What is ALK again? I forget.
Anti-Lift Kit. Basically it helps stop the front end of your car from dipping in under hard braking/cornering and from lifting at launches. I believe it also adds some positive caster, which helps with turn in.
http://www.rallitek.com/whankit.html
Also, his car was non-turbo, so he upgraded to WRX and SS parts. The SS comes with 18mm swaybars front and rear.
asc_up wrote:Anti-Lift Kit. Basically it helps stop the front end of your car from dipping in under hard braking/cornering and from lifting at launches.
It's actually the opposite of this. The stock suspension geometry has anti-dive geometry built into it. The anti-lift kit removes some of this which helps keep the front end from lifting under acceleration. In theory there should be some more dive under braking, however I don't have an ALK, and can not comment with any direct experience.
The ALK also does add caster, which in turn add dynamic camber during corning.
asc_up
Post by asc_up »
Oh, didn't know that. Thanks for the correction!
