Coolant Temp. Sensor Location?
SubiePrice88
Post by SubiePrice88 »
Im trying to replace the Coolant Temp. Sensor on a '91 SS.
I did a search but Im on dial up right now and it takes FOREVER to load and I havent found what Im looking for.
The stupid haynes manual says "....located in the coolant pipe under the right-side intake manifold runner."
I believe I changed out the sensor before but it was on a N/A.
I cant seem to find it and it seems like the turbo is in the way?
Need some advice and Help!
-Thanks!
-Jordan
"Nothing Stings Like a Subee"
1993 Legacy Wagon, 5MT, 220k!
gijonas
Post by gijonas »
Its on the driver side under the manifold,on the coolant pipe.Look down from below (you may need to move a couple small things) and you will see the sender with one wire and the sensor right next to it with a brown plug i believe.I know someone has a pic as it was just posted recently.
SubiePrice88
ah ha! Found it! That was easy...
Thanks for the help!
-Jordan
