I ordered gaskets for my throttle body spacer that I'm making to allow me to mount my EJ22T throttle body onto my 97 forester JDM intake upside down.
I also ordered the bolt and sleeve that bolts the shifter to the shift linkage.
Tonight when I go to my parents house I'll probably work on cutting the spacer out and filing it down smooth.
Maybe I'll heatwrap my exhaust manifold too!
I redid a couple of the underhood grounds that were all corrodded. Also sounds like I might have to thin the oil mix I made up out as I had some lifter noise today on startup when it was fairly cool outside.. Guess I need 3 quarts of 5w20 to 2 quarts of 15w50
changed my knock sensor and wires which no difference except maybe the wires making it a bit smoother, and later swapped back to the stock coil pack and noticed the car seemed a bit quicker!
Cleaned my IACV, replaced the air filter (pureone since it was just 3 bucks more than the regular $9 purolater filter) and found out my PVC is completely clogged (It wouldn't clean up, so i'm going to get a new one tomorrow after golfing).
Oh and of course after the work I had to take it for a "Test Drive".
Ed
91 Legacy L Wagon
03 Legacy L SE Sedan
07 Toyota Tundra 4X4
I installed the simple, non-"torque box", intake on the BK4 last night. Lots more sound (more like the Cobb), and the intake hum is far quieter. I like.
Cleaned air filter, Cleaned MAF and houseing, Painted part of my intake, Removed my charcoal canister, cleaned the inside of the car
Rust converter dried, I zinc coated the insides of the front and rear frame rails, front inner body, and misc. spots on the tailgate that the window trim had been partially hiding.
tested a paint color on the body and found the color is too white for the car - pearl white duplicolor is NOT the same as 91 SS pearl white
- repaired a nasty fuel line , verified the radiator fans turn on properly
- picked up a fog light switch from the boneyard and front sidemarker lights
tore down the old motor to just a shortblock (bad bearrings), cleand the heads and such then went to the junkyard and took a shortblock out of a 91 wagon with 170k miles...with no plyers, cutters, 22mm, engine hoist, or alot of other things a guy who works on cars for a living should have rememberd to take to the junk yard lol. We got the head bolts out using a 6" 3/8th drive ratchet and using the coolant crossover pipe as a cheeter pipe! It was quite an interesting day lol.
Diagnosed a bad injector and now I have to park the car while I try to find a set of JDM sidefeed 440cc injectors. I'm thinking about just using stock EJ22T injectors. I'm only running 11psi of boost out of a VF8, but I don't know if the stock injectors can handle that.
impreza_GC8 wrote:Diagnosed a bad injector and now I have to park the car while I try to find a set of JDM sidefeed 440cc injectors. I'm thinking about just using stock EJ22T injectors. I'm only running 11psi of boost out of a VF8, but I don't know if the stock injectors can handle that.
I thought the stock fuel system was good for 16 psi? Someone correct me if I'm wrong.
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
