Center Diff install complete!!: WHINE FOUND!: NOW WHINING!
- quasi-mod-o
Just one more thing to check...
... you haven't done any movie shoots recently right?
If so, I hope you didn't roll it over.
Subarus are known for their driveshafts falling out when the car rolls over.
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
Soul Shinobi
There's a method for testing the center diff on the car, I'm surprised no one brought it up yet (maybe we just thought you'd procrastinate getting a driveshaft in
I'll be honest I'm not 100% sure what the procedure is. I think you have to lift one end of the car and keep one end's wheels on the ground, then try to rotate both tires in the air in the same direction (friend required). I don't remember what the result are supposed to be exactly. For you, I expect it to bind and not turn, but I don't know to what degree this is acceptable.
Someone finish/correct this for me here.
-Nick
1992 BC Legacy L Sedan AWD 5MT 272,000 - Wish you the best
1998 BK Legacy L Wagon 5MT 234,000 miles - RIP
2002 SF Forester S Wagon 5MT 215,000 miles - Current winter sleigh
1986 FC Mazda RX-7 GXL Coupe 5MT 155,000 miles - Summer cruiser
- quasi-mod-o
It can be done with the trans in the car. I haven't done one, but you just have to take the rear transfer case off.
fishbone79
Yes, there is a way to test it in the car, and I thought it had been posted previously on this forum, but I can't seem to find it... I'm a little fuzzy on the details too, but I believe it's something like rotate rear tires in the same direction as soul shinobi says, and watch for jumpyness or some other qualitative thing.
The diff can be swapped in the car. I have one that I have no need for, but I need confirmation that the center diff in the NA MT is the same as the turbo MT. I think they are, but I am not positive... anyone?
Cheers,
morgan
1992 Legacy BF
morgan
1992 Legacy BF
from this thread:
http://bbs.legacycentral.org/viewtopic. ... entre+diff
theres only 2 types, phase I and phase II they different and only by years.
91-98 and 99+
are you in WA or another state?
91-98 and 99+
fishbone79
I'm in NJ, haha. USPS priority flat rate box is ~$9 in that size, i think. I will dig the thing out and make sure its visually OK. The transmission it was removed from was working fine, I just wanted a few parts off the mainshaft for a rebuild I was doing. If it doesn't work, just let me know and I'll send your $ back, NQA.
Cheers,
morgan
1992 Legacy BF
morgan
1992 Legacy BF
A few things I'll add-
Driveshaft lengths are not dependant upon the model of the car (Impreza vs. Legacy). There are only two different length driveshafts. (length aside, there are other differences but that doesn't matter at this point).
Long - 5MT
Short - Auto/6MT
Center Diff replacement isn't too bad and can be done with the trans in the car. Skoobywrx posted the link to my How-To. It should explain everything.
Still pretty weird that half of the driveshaft was removed...
Long - 5MT
Short - Auto/6MT
SUBARUEHS Racing
Soul Shinobi
The hell... Maybe it's the viscous fluid from the viscous coupling unit that bled out during extreme overheating? Just a guess.
-Nick
fishbone79
fishbone79
whine seems to coming from underneath the car....im assuming the transmisson. i cant pinpoint the area right now.
one observation: the sound increases in pitch as the the speed goes up. no change in sound or pitch if a gear changes. even at neutral coasting the sound is there.
sounds like if the car is on a dyno......like a really loud tires...increase in pitch and sound as you go faster....WTF?!
