Transmission Access Panel?
Locked
formview
Post by formview »
Hi. I recently had my transmission worked on, and now that I have it
back I noticed that I can see the bottom of the torque converter and
flywheel/teeth just below the engine (you can see it spinning when
the engine is running). I was wondering if my mechanic "forgot" to
replace the access panel, or maybe there wasn't an access panel all
along. If there was an access panel would the transmission have to be
pulled to put it back on? Thanks.
Will You Find True Love?
Will You Meet the One?
Free Love Reading by phone!
http://us.click.yahoo.com/7dY7FD/R_ZEAA ... /XoTolB/TM
j k
Post by j k »
Yeah, looks like your mechanic forgot the panel/dust shield. Is is a thing
guauge metal plate that covers the last couple of inches between the bottom
of the motor to the tranny, covering the flywheel and providing a place for
any moisture/water to drain. You shouldn't have to yank the tranny to
replace it, well, your mechanic to replace it since he screwed up. It might
be a squeeze but try removing the upper tranny ant-pitch bar (goes from the
top of the tranny to the firewall) and then the two lower motor mount bolts,
then lift the engine and tranny together to get some room to replace the
panel (it is held on by two 10mm or 12mm bolts, nothing major). Hope this
helps. john k
>From: "formview" <yahoo@mintzer.com>
>Reply-To: BC-BFLegacyWorks@yahoogroups.com
>Subject: [BC-BFLegacyWorks] Transmission Access Panel?
>Date: Tue, 30 Jul 2002 05:51:31 -0000
_________________________________________________________________
Join the world’s largest e-mail service with MSN Hotmail.
http://www.hotmail.com
Free $5 Love Reading
Risk Free!
http://us.click.yahoo.com/NsdPZD/PfREAA ... /XoTolB/TM
formview
Post by formview »
Thanks. I didn't remember the hole being there, but then I never
specifically looked for it either.
Risk Free!
Locked
