Electrical problems abs light, no hvac, won't go into drive
So the other day my mom was telling me the car wouldn't go into drive I figured I guess just the solenoid. Well not the case. Went to try today did it again and I also noticed the abs light and no hvac. So I hit the dash and various areas around the shifter and voila hvac was blowing air, i could shift again, and when i restarted abs light when out. My guess is a bad ground. Question is where do you think this ground is? Any suggestions and comments would be great thanks guys!
Car: 94 Legacy Turbo Sedan 207k km
dug around didnt find anything unusual. Anyone have a wiring diagram.
lol 0 feedback as to why these issues occured? Nothing happened lately.
BSOD2600
Post by BSOD2600 »
Painful I know.. but have you looked through the wiring diagrams in the FSM? See what circuits / harnesses / connectors those two systems have in common? At least that would give you a starting point when digging under the dash for connectors...
'11 WRX Limited
'94 TW | R.I.P.
didn't look real hard. Hopefully everything is fine though!
