Odd Request. ej22t -> ej22e
Weazel240
Post by Weazel240 »
Dont ask me why i wanna do that, i have a rollin wagon shell.
i wanna do a lil project, plus i would like to get the wagon to run to haul junk in.
Its a 94 turbo wagon shell. IF i get a 94 ej22e engine and harness and ecu it should all just plug and play correct?
Install engine, plug in 94 ej22e harness and ecu and thats it?
no need to splice wiring harness correct?
I have a reg engine crossmember and a non turbo radiator.
is this all i pretty much need?
Halp me plz! thanks
You shouldn't need the harness. If you do a search, you should be able to find which wires to switch at the ECU.
Weazel240
Post by Weazel240 »
i forgot to inform, the shell doesnt come with a Xmember, engine, ecu, and harness.
Ah, well you'll need the exhaust, too.
Weazel240
Post by Weazel240 »
yah i know that. but my main concern is the harness. it dont need to be spilced correct?
Weazel240
Post by Weazel240 »
Bummmp me
Where was the harness cut? You *shouldn't* have to do a whole lot to make it run.
Weazel240
Post by Weazel240 »
harness was uncut.
the shell is missing the engine harness.
i guess who took the engine, took the whole swap set,(engine xmember, ecu, harness)
SO i wanna replace the shell with a ej22e.
DO I NEED TO DO SPLICING? or is the 22e harness will all plug in? hello? thanks
asc_up
Post by asc_up »
Nothing will need to be spliced or switched around at all if you have the EJ22E harness and ECU.
wtdash
Post by wtdash »
asc_up wrote:Nothing will need to be spliced or switched around at all if you have the EJ22E harness and ECU.
+1
and as stated above you'll need the NA exhaust, too.
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Matt Monson
Post by Matt Monson »
Just make sure it's a 92-94 engine harness. The 90-91 engine harness with the round connector won't work with your chassis harness. You need the engine harness that has 3 rectangular connectors.
Then all you need to do is move around a few pins at where the ECU plugs in to the chassis harness and you are good to go.
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Pretty sure all the 90-91 non-turbo engines used the 3 rectangular connectors, while all the turbos had 2 rectangular, and 1 round connector.
wtdash
Post by wtdash »
Legacy777 wrote:Pretty sure all the 90-91 non-turbo engines used the 3 rectangular connectors, while all the turbos had 2 rectangular, and 1 round connector.
I'll probably go to hell for disagreeing w/Josh, but my '91 Turbo Connnectors matched my '90 NA Connectors when I did the swap...plug for plug.
Td
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Matt Monson
Not the NA 90 wagon that I did my first swap on. Maybe it was a US made vehicle versus a Japanese vehicle made thing. I know we've found discrepancies in the past that led to what factory the cars came from versus the year and model.
Suby Hai!
Weazel240
Post by Weazel240 »
thanks everyone for the help.. But i just wanna up date...
as the first post states..
_ i have a 94 turbo automatic wagon with NO ENGINE, ECU, HARNESS.
I wanna throw the ej22e in.
I am about to pick a WHOLE 1992 Legacy from a local guy. Its complete minus front calipers, with slight front damage.
the engine runs, new HG, Tbelts, aux belts, no Over heat, But it is stick shift.
****** as for my auto trans wagon, all i need to do is pull the clutch/flywheel off the ej22e and throw on a Torque converter correct?
other then that.. the engine, and wires should all be plug and play with correct non turbo automatic ecu..
please confirm.
Lunatech
Post by Lunatech »
Where are you located? Maybe I'll just come take it off your hands.
Robert,
Rio Red 1990 L sedan 5MT at least 302000 mi. and Spruce Pearl 1996 Wagon 4EAT 245000 mi.
georryan wrote:
Don't knock him for thinking outside of the box. At least he has been creative.
Td
Just looked in the parts book, and yes the 91 turbo harness uses the three rectangular plugs.
My bad....memory is going in my old age :lol:
Lunatech
Post by Lunatech »
Whatever.
Robert,
Lunatech wrote:
Whatever.
Where am I......
tturnpaw
Post by tturnpaw »
Im doing the same thing to get my wagon running. Im taking all the control boxes etc and swapping them. My question is, since im using a 90 harness in my 92 ive noticed after cutting the strand of wires that runs to the horn and headlights that the gauge of the white/red wire and the other wire are larger in the 92.
Could this be a fault the 90 had that the 92 was solved? A couple wires dont match up either.
Lunatech
Post by Lunatech »
Josh,
I thought you were in Houston...but your standing right behind me...aren't you?
Robert,
tturnpaw wrote:Im doing the same thing to get my wagon running. Im taking all the control boxes etc and swapping them. My question is, since im using a 90 harness in my 92 ive noticed after cutting the strand of wires that runs to the horn and headlights that the gauge of the white/red wire and the other wire are larger in the 92.
It could be....the wiring in these cars is a little anemic, and they may have bumped up the gauge a little.
