need to know if 92-99-SUBARU-WRX-IMPREZA sills will fit leg
yazmo
Post by yazmo »
anyone know if 92-99 SUBARU WRX IMPREZA STAINLESS DOOR SILLS SILL JDM would work in legacy 94 sedan car look like about the same size.
just need confirmation
ebay link
Since they're just double sided tape, you could probably make them work, but may look a little funky.
I can try and take a measurement between my legacy & impreza to see if the length is correct.
yazmo
Post by yazmo »
i would like if its no too much of a problem!!
I looked yesterday and the legacy sills are longer and little deeper than the impreza sills. Those do look a bit long.
All I can suggest is to try them out. But that'd be your call.
Aerotech
Post by Aerotech »
I have something similar... as long as it's a set for a 4-door, you should be fine.
These are taped right on top of the original plastic sills.
Jerry
NICO
Post by NICO »
that looks amazing Aerotech
