Engine Mounts
race_to_live
Engine Mounts
Post by race_to_live »
I pulled the engine out yesterday and found I had 4 engine mounts, that is 2 mounts split in half. Where can I find some?
-91ss, 250,000mi rebuilt, tmic, tdo4, agx's w/groundcontrol, f/r strut bars, rust
-83 gl wagon...350,000mi custom dents
-62 honda 55, (moped)
-74 Yamaha rd 350
ScottyS
Post by ScottyS »
I used stock STi mounts as replacements.
1991 SS build thread: http://bbs.legacycentral.org/viewtopic.php?t=40430
race_to_live
what year of sti mounts did you get? Or what years will fit?
-74 Yamaha rd 350
BSOD2600
Post by BSOD2600 »
I ordered the STI Group N engine mounts from the dealer. The brackets that come with it are slightly different from stock. I ended up using the STI engine mount and the stock mounting plate. All bolted up just fine.
'11 WRX Limited
'94 TW | R.I.P.
ive got a set of motor mounts for sale. 40 plus shipping. pm me if you want them
adema2626
Post by adema2626 »
BSOD2600 wrote:I ordered the STI Group N engine mounts from the dealer. The brackets that come with it are slightly different from stock. I ended up using the STI engine mount and the stock mounting plate. All bolted up just fine.
The other plates are just a little bit bigger and beefier. There was no need to use the stock plates because the other ones bolt on and mount just fine.
93 Imp wag, 94 Imp wag WRX swap, 99 Imp Sedan WRX swap, 01 Imp Outback Sport, 05 Outback XT, 00 Outback, 98 Outback, 93 Leg touring, 93 Leg wag, 94 Leg wag lifted ej22t swap, 79 Brat 4x4 EA81 4spd d/r swap, 97 Crown Vic lifted
BSOD2600
Post by BSOD2600 »
They ARE different:
Holes are in different places:
'11 WRX Limited
'94 TW | R.I.P.
They'll still work though. Been running the STi mounts for some time now.
BSOD2600
Post by BSOD2600 »
Legacy777 wrote:They'll still work though. Been running the STi mounts for some time now.
With the STI or stock plates? I'm not disputing the STI Group N mount will work fine.
'11 WRX Limited
'94 TW | R.I.P.
adema2626
Post by adema2626 »
Your pictures didn't work. I wanna see this because I am running the STI group N mount and bushing. I had no problem with installing it. I just wanna see your pictures because maybe I got some weird plate or something.
kleinkid
Post by kleinkid »
Yes, the plates are different. So what? They bolt up to my '91 SS perfectly. STI GR. N rubber and steel have been on for five years, no problem. They probably were designed to be used as set, for a reason. Use the plate and rubber together. Or do what ever you want.
MikeyMeyagi
Post by MikeyMeyagi »
i used both the sti plate and mount. engine bolted up fine.
*sold*
The reason they're different is because the bolt holes for the engine mounts are directly in line with the mounting holes on the outsides. This is said to reduce stress on the plate and bolts because this way there's no leverage.
I'd use the STI ones with the holes lined up. I installed Group N STI mounts. I can't remember if I used the stock EJ20G plates or the Group N plates. There's probably pictures of it in my build thread. I almost think I may have used the stock ones because they had heat shields but I'm not sure.
Dynamic Entry
Post by Dynamic Entry »
+1 on using the STi plates that come with the Grp N mounts
No problems here after 2 years
Andrew
16 Outback - wife's daily
95 Gravel Express - Sold
92 Green SVX - RIP
02 WRB WRX - Sold
Pretty sure I used the STI mounts with their plates as well and had no problems.
magicmike
Post by magicmike »
I used them as well. no problems at all.
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
Yeah....I used the sti plates that came with the mounts.
