does this sound like a recipe for disaster?
awdimprezal
Post by awdimprezal »
1996 impreza L AWD boosted n/a 2.2. 60 trim T04E turbo, well over 200k miles, 11 psi daily. No management.
asc_up
Post by asc_up »
Haha let me help you out. Do you have the picture on your computer? If so, upload it to tinypic.com real quick (or photobucket.com if you have it) and then post the link on this site.
awdimprezal
That link right there should work.
asc_up
Post by asc_up »
The picture isn't showing up for some reason.
asc_up
Post by asc_up »
Do we have to be a member of that forum or something?
awdimprezal
Nevermind, I cant do anything from here @ work. fail. I'll fix it when I get home.
casanovaw
Post by casanovaw »
Still not working
92 SS
03 ZX6R
dkopp
Post by dkopp »
good point that the 4eat slushbox doesn't put out the same power and has lower shift points, but i would think that both aren't enough to explain the difference in output given the efficiency range of the turbo. more so, the chip is pushing 17psi v. 11psi.
i'm all for reliability and revtronix rocks for that and consistency, but this hobgobblin of an engine convinces me that subaru engines deserve respect. seeing that 2.2 N/A engines are a dime a dozen, in a pinch i'd go this route in a second because i just don't believe this is a fluke. a fluke doesn't go to 200K miles... plus, it sounds like a freakin' jet!!! how, cool is that next to a ricer civic? that's something v-8 guys could appreciate.
my apologies if that wasn't a real dyno plot. i thought it was from a customer car. now, someone's going to say, "well, it was this dyno so the real number is (pi x r^2) x (blah, blah, blah)..." which i was trying to avoid.
cheers
asc_up
Post by asc_up »
Right, but he's also running a T04E, the Revtronix chip is designed for a TD04-13G. A T04E is about the size of a TD05-16G, so he's probably flowing about the same amount of air at 11PSI that a TD04 does at 17PSI, but the air that he's flowing is cooler, so it's going to be more efficient.
Gotta be a member to get the attachment to show up....
awdimprezal
http://www.i-club.com/forums/showthread ... ost2751165
That should work now, once and for all. Bottom of page.
asc_up
Post by asc_up »
Still had to sign in to view it. Is this being run on the stock N/A ECU?
awdimprezal
N/A 2.5 DOHC ecu.
asc_up
Post by asc_up »
Any idea what's up with the dip in power around 4K RPM?
awdimprezal
I think thats where the MAF maxes out, Or thats where it saw some knock and started to retard timing.
asc_up
Post by asc_up »
Ah gotcha. I'm just so f-ing impressed that you're running that much boost out of that turbo on a STOCK N/A ECU. Haha amazing!
awdimprezal
I dont take it easy on this thing either, I piss pound it.
