Devan's Swapped 91 SS |New Pics Last Page
livestrong14
Post by livestrong14 »
Thanks man! it was great to meet you, your 3rd gen sounds amazing!
91 SS -Carbon Bronze Pearl
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
91 Rio Red SS- RallyX Project
93 AWD Sedan- FOR SALE!
livestrong14
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
Redlined
Post by Redlined »
Couple a years ago I was working in a Chevron station, Had to sell those Beast cancer Bracelets. Made most of my sales with "Got a dollar for breast cancer? You get a nifty bracelet, show your girl you care about her tits!"
livestrong14
Here are a few more updates:
Got some good deals on some "used parts" I love the used performance aftermarket!!
pictured are a pair of Cusco braces, new rear lock bolts, new camber bolts, and some uber nice brake fluid :)
Also got some used APS intercooler pipes and couplers. They fit great!
Here they are mocked up with the used Perrin big maf I got, also with my old HKS short ram
pretty tight clearances:
And finally here is a used Taylor battery relocation kit I got for the APS pipes, the quality is great and the aluminum box sits in there very well.
I am going to be putting the wingless trunk back on here in a couple weeks, I miss it!
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
Looks good. Have you driven the car hard enough to notice the bracing?
I will be making my own triangle brace for the rear out of aluminum tubing and heim joints.
Mattheww044
Post by Mattheww044 »
Nice meeting you at WCSS 11 Devan, the car looks and is all out amazing. Pictures don't serve this car it's justice guys. So that means everyone needs to go to WCSS 12, we need a bigger group of Leggys there. But don't plan on winning, Devan will be tough to beat :D
asc_up
Post by asc_up »
Nice deal!
You ever going to put that STi rear window defuser on? I want to know how it fits/how badass it looks!
livestrong14
Thanks guys! Dan, When I installed the fender braces and strut bar I felt quite a big difference in the stiffness of the front end. It tightened things up a lot. The steering rack bushings and the PSRS also helped a ton. I haven't been able to auto-x or do any track days since installing the coilovers. I plan on testing the capabilities of the car out at PIR in the spring.
Matt, thanks again man it was a pleasure to meet you. I looks forward to next year!
Aaron, I am planning on cutting down the diffuser and using it under the car. I need to make some custom brackets to make it mount like one on a 06/07 sti
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
livestrong14
Today I started a design for a filter heat sheild
It will be made out of aluminum, not too thick, I still want a little flexibility. It will bolt to the stock ABS bracket.
It fits around the PERRIN big maf and HKS intake very nicely!
The plan is to have it powdercoated black with some gold reflective tape to reflect heat back towards the motor.
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
livestrong14
Updated Mod List 2009/2010
Engine & Drivetrain
Full OBD2 Conversion using an 02 WRX wiring harness
04 WRX ECU
EJ257 block
Arias Custom Forged pistons
Eagle H-Beam rods
ACL race bearings
WRX heads
STi Cams
ARP headstuds
Cometic headgaskets
WRX intake manifold
TGV deletes
Ported and coated exhaust manifolds
Auto to manual transmission conversion
JDM Legacy GT Spec B 4:44 transmission
V3 STi 4:44 LSD rear diff
98 Forester hydraulic clutch master cylinder
Exedy Stage 1 clutch
B&M short throw shifter
PERRIN shifter bushings
Gates Racing timing belt
Godspeed Spec R FMIC
APS DR525 FMIC piping
APS stainless coolant tank
FP Red 8cm turbo
Modded 810cc WRX injectors
Walbro 255 fuel pump
Perrin fuel rails
Covert Performance air oil separator
Perrin 3" turbo inlet
Perrin BIG MAF
HKS Short Ram
SimplySubie titanium intake heat shield
GPmoto 3" Downpipe
EKGM 3.25” Cat-Back
TurboXS RFL BOV
RalliTEK radiator shroud
Project Kics magnetic oil drain plug
Greddy Trust oil cap
AC Delete
Suspension & Brakes
TEIN HA coilovers
Cusco front lower tie bar
Cusco rear lower tie bar
Cusco adjustable rear strut tower bar
STi carbon fiber front strut tower bar
Legacy BC5 OEM rear trunk bar
Whiteline 22mm front swaybar
Whiteline 24mm adj. rear swaybar
Whiteline Endlinks F&R
Whiteline subframe lock bolts
Whiteline steering rack bushings
SimplySubie Fender Braces
PERRIN P.S.R.S
RalliTEK exhaust hangers
RalliTEK swaybar bushings
AP Racing Stainless brake lines
Brembo slotted rotors
Metal Masters brake pads
WRX calipers
WRX ABS conversion
WRX master cylinder
WRX steering rack
Interior
93 Legacy Turbo black interior
Front door panels by Shelby Shafer, custom fit to WRX dash
WRX dash conversion
WRX center console
WRX pedals
STi shifter trim
Autometer dual gauge pod
Prosport 52mm boost gauge
AEM Uego wideband
JDM red hazard button
OEM auto dimming rear view mirror with compass
Sony Xplod headunit
Nardi Taniguchi steering wheel
Nardi personal hub adapter
Greddy Trust counterweight shift knob
97 Outback manual seatbelt conversion
01 2.5RS front and rear seats
Sound Deadener removed
Stripped trunk
Exterior
Custom Painted Carbon Bronze Pearl
17X9 DR31’s Wrapped in 235-40-17 Goodyear Eagle F1's- daily
16X7 Rota Slipstreams wrapped in 225-55-16 Kumho V710’s- track
JDM headlights
EDM marker lights
Jaymzz grill
Kakumei WRC hood vent
89 ½ Legacy rear trunk
93 Legacy sedan factory black trim
Body colored side molding
Body colored door handles
Body colored mirrors
Shaved side emblems
EVO 7 grill mesh
Tinted, amberless rear tails
JDM Legacy BG L7 Badge
Thanks to our friends and generous sponsors:
Northwest Subaru Service
Surgeline Tuning
Forced Performance
RalliTEK
Bearing Services
SimplySubie Performance Parts
Last edited by livestrong14 on Sun Feb 28, 2010 6:56 pm, edited 10 times in total.
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
livestrong14
Swapped window trim today!
It cleans up the outside a lot IMO
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
asc_up
Post by asc_up »
Forgive me, but what's the difference?
I looked at it for a while and kept comparing the two and the only difference I see is one is glossy and one is flat black. He mentioned a triangle something or other but I don't see it.
jake15
Post by jake15 »
asc_up wrote:Forgive me, but what's the difference?
it has no chrome on it.
car's looking awesome devan! i'm pretty jealous of you're blacked out window trim :-)
livestrong14
Here is an example of a stock 90/91 SS
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
livestrong14
Hey Jake, thanks man! It was just one of those ideas I had and I gave it a shot! I'm jealous of your entire drivetrain haha! I can't wait to see the new engine setup! how's the 257 coming along sir?
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
asc_up
Post by asc_up »
D'oh! Now I see, I forgot that our years had chrome trim on them. Hmmm, maybe I need to look into doing that...
livestrong14
Installed a RalliTEK radiator cooling panel today! It is meant for a 02/03 WRX but it fits with the stock '91 brackets pretty nicely!
thanks RalliTEK!
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
joeWM
Post by joeWM »
DEVAN!!!!!! TINT THAT BITCH MAN!
[quote="kimokalihi"]Jesus, that's a grocery list of problems.[/quote]
92 Legacy SS 5MT....sold :(
02 Aspen white WRX Stage 2, 20%tint
livestrong14
THIS SPRING TIME DOOOOOOOOD!
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
livestrong14
Slicks teaser ;)
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
livestrong14
Finally got the old door panels off. They were hitting on the wrx dash. I got around to mocking up the new custom panels today. Still have to have the other side made.
old:
new:
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
Who made them?
They look nice!
livestrong14
Thanks Josh! A buddy of mine does custom upholstery. I did some trading with him and got these :) I'm pretty stoked with how they turned out!
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
Yeah, they really do look very nice!
