SVX Injector size?
Snorkus, filters, throttle bodies and intake manifolds.
martimus919
SVX Injector size?
Post by martimus919 »
I picked up some SVX injectors and would like to use them for my SS for when i get the Stage 2 Revtronix chip, but i don't know what size they are. So any one got any idea of where find out the size?
PhyrraM
Post by PhyrraM »
I'm not sure of the size, but considering that the SVX was rated at 230HP from 6 cylinders (~150HP if it was 4 cyl), the injectors are most likely about the same as any other normaly aspirated injector. In other words....Stock SS injectors are most likely higher flowing.
martimus919
Ya I was afraid of that
wtdash
Post by wtdash »
From HERE:
The SVX injectors are side feed and from what I can tell are rated somewhere between 260-275cc/min.
and HERE.
the injectors are a different story as they are 275cc jobs that are going to be maxed out at 250 HP.
Based on Opposedforces.com the SVX injectors are a unique part number, but I'd bet the EJ22/25 red injectors would also work as they are rated around 280cc.
Td
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
gijonas
Post by gijonas »
The eg33 is a 2.2 with 2 additional cylinders.Therefor the injectors are most likely the same parts as the ej22 N/A.
