Engine Building...
logan9691
Engine Building...
Post by logan9691 »
so I have the EJ22T stripped down to the block and will split it next weekend so it'll be ready to be bored out. Now i need to think about internals, specifically the pistons and rods. I want to run the wiseco EJ22T hybrid piston b/c i'm gonna be running the EJ25 DOHC heads, now i need to find some rods to go with the pistons, there are K1 h-beam rods for the EJ20/25 and i figured thats what i needed but i'm not 100% sure.
Thanks for any info on rod choices.
Logan.
VF43 custom FMIC APEXI intake Invidia 3" TBE JDM Ver. 4 RA STi trans (4.44) SPT short shifter rear LSD WRX rear axels coilover suspension JDM 4-pot front brakes drilled slotted rottors Greddy EBC tuned 20G ECU sti 550cc injectors Jecs MAF walbro 255
PhyrraM
Post by PhyrraM »
Any rod designed for either the WRX EJ205/207 or the STI/LGT/FXT EJ257/255 will work.
The common low-buck upgrade is USDM STI EJ257 rods.
logan9691
Post by logan9691 »
ok...how well would the STI rods hold up to 300-350ish hp?
gijonas
Post by gijonas »
Fine. RPM is what kills rods not HP.And not all upgrades are "upgrades".
race_to_live
Post by race_to_live »
what are the "hybrid pistons"?
and the rods? are they just a better rod or is there some kind of stroke difference involved?
-91ss, 250,000mi rebuilt, tmic, tdo4, agx's w/groundcontrol, f/r strut bars, rust
-83 gl wagon...350,000mi custom dents
-62 honda 55, (moped)
-74 Yamaha rd 350
