wireing face-lift corner lights to blink on pre facelift car
LostinMaine
Post by LostinMaine »
ok there was a bunch of talk about doing this without doing the face-lift swap, but i have everything i need to do a face-lift on my 91 except the fenders, and my main question is to wire up the blinkers to the corner markers do i need to find a 2 filament bulb that will work and find a new plug with 3 wires and just extend the signal wire from the pre face-lift blinks to make this work?
thanks
eric
Co Founder of MaineSubies.com
91 SS, in need of some major TLC (work in progress)
Im lost in Maine, but ill find my way out eventually
The connector will likely be different, but you should be able to find one and just splice it into your pre face harness.
LostinMaine
ok thanks!
LostinMaine
does someone have a picture of what im looking for? and how does the turn signals work on a 92?
macipusy
Post by macipusy »
All you need is the bulb and harness from a 92-94. You can test the wires on a battery to see which filament is the blinker (brighter one) and which is the corner light.
You have to cut the connectors off the blinker and the corner lights.
After that you splice the grounds together on your pre-facelift car, and route the power from the bumper blinker to the new bulb harness.
I did this on my 91 without the face lift by cutting the bulb receptacle off the 92 corner lights and plastic weld them to my 91 corner lights.
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
