stock psi on ss legacys?
josh_90_leg
Post by josh_90_leg »
just what the title says, how much psi do stock turbo legacys push? like the 91-93 years if that makes a differance
BSOD2600
Post by BSOD2600 »
Believe its 7.8 psi
'11 WRX Limited
'94 TW | R.I.P.
josh_90_leg
gotch ya, ya i thought it was like 7, a friend thought it was 8, so i guess its kinda in the middle haha
SubiePrice88
Post by SubiePrice88 »
This doesnt say stock boost, but its helpful and has some good info:
http://legacycentral.org/library/turbo_faq.htm
-Jordan
"Nothing Stings Like a Subee"
1993 Legacy Wagon, 5MT, 220k!
wtdash
Post by wtdash »
According to THIS, stock boost is 8.7.
I've read wastegate is 5-7psi and stock fuel cut is 13psi.
Td
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
206er
Post by 206er »
i see right around 8. no telling how accurate my gauge is though, its autometer but its old.
A1Fiddler
Post by A1Fiddler »
8.7PSI. My boost gauge reads right under 9.
'92 Legacy Sport Sedan - EJ22T, 4EAT, AWD - Snorkle Delete, Custom Grounding, 3" Catless TBE.
impreza_GC8
Post by impreza_GC8 »
It was about 8psi for me. Easily turned up to 12psi with an MBC assuming the rest of your engine can handle it. At 13psi the stock ECU cuts fuel.
free92leg
Post by free92leg »
haha 7.8 i was closer
